Any Options on a G80 10bolt?
Discussion in 'The Garage' started by rivermtnman, Apr 19, 2006.
  1. rivermtnman
    rivermtnman 1/2 ton status
    Nov 7, 2003
    102
    Lebanon, VA
    I got my old '88 back from my brother... with the rear end out of it. I'm trying to get it ready for Harlan, Ky Memorial Day weekend.
    I opened it up and the spiders are shot. I was thinking of putting a spool in there, but cant see how to get the side gears out because of the two rods holding the mechanisms that work the limited slip?
    Can you even put a spool in the G80? Could I swap it out with a carrier from an open diff 10b?
    I'm just wondering if there might be a cheap fix.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You can't do anything with a 10 bolt govlock .
    Options are :
    Replace carrier , or replace whole axle assembly .
    I would choose the axle replacement with a used unit with the same gear ratio .
    Open 10 or 12 , so you can get a Lockright .
    Or you can be "Normal" here and replace it with a 14 bolt full floating axle . And convert your truck to 8 lugs . Weld it or buy a locker .
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Put in an eaton posi.
