any other machinists here?
Discussion in 'The Lounge' started by rdn2blazer, Jun 7, 2005.
  1. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    just wondering how many out there are machinists like myself that are members. what kind of shops does anyone work at, job shops, production, protype, whatever. i have 15+ years as a machinist in cnc mills and lathes and all conventional equipment and have surface grinding expeirence. i also do all the welding in the shop. currently leadman at a conventional only production/tooling/prototype shop. we are a FAA certified repair shop, so our "production" parts are repairable parts. we dont make parts from scratch just tooling to run parts in the machine shop and our grind shop and spray shop. we are primarely a plasma spray shop for most all other industries. any fellow machinist out there? :)
  2. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    I do maintenance and can run a mill, lathe and such. But i am slow since i stay away from this work and usually do other maintenance from the working on robots (panasonic or fanuc), welders, injection molding and fiberglass sheet molding machines. I would rather do hyd or mechanical maintenance than the machining stuff.
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Work at a small job shop that does production, prototype and R&D. Shop forman with 10 years of cnc lathe and cam driven screw machine experiance. Manual knee mill, engine lathe, suface grinding and turret lathes also. I'm the welder here too. Programming, set-up, operater and maintenance, do time studies for quoting new work. Only thing I'm not is the boss, think I need to work on that one :laugh:
  4. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    I have been working four years at a CNC shop making clutches and starters. I still have a lot to learn.
  5. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    hay guys thanks for the replies. i love being a machinist, knowing how to make most anything. knowing how to weld and fab to. alot of my friends are allways asking me to make stuff or help fab stuff, its a great trade and skill to have. ive made everything from toys to F-16 parts, helicopter, satalite parts, racecar parts, you name it. parts for DisneyLand rides, rocket parts for our countries deffence. i worked for a shop where we made hubs and axles and other parts for formula 1 and cart racing cars. we supplied about 70 % of the teams in cart racing and alot of the F1 teams in Europe. it was pretty cool. our hubs we made had 4 different diameters that had plus/minus .0001 tol. that was fun. i took a guys job there cause he could not hold to that tight a tollerence. not what i wanted to do, but he couldnt deal with the tight stuff ane all our parts were tight tol. parts, my boss said he allways gave this guy plus/minus .002 stuff. it was all 300M steel, tough stuff on inserts. that was the first shop that i had gotten away from aerospace/aircraft parts. i should have stayed there but after awile i left for more money. now the shop i work at has no cnc, i miss it cause of the technology, but i dont miss the pressure of cnc production. i dig the dificult close tol. conventional stuff we do here. it can be chalenging work. im trying to talk my boss into atleast a cnc tool room mill and lathe to do some of our tooling faster. hope to get that soon.
  6. rhino105amx
    rhino105amx 1/2 ton status
    Sep 13, 2002
    159
    Mesa, Arizona
    I have worked as an aerospace machinist for 26 years. Currently running CNC ID/OD grinders and am certified as a QA inspector, but have done most everything, lathes, mills, gear grinding equipment. Stuff even most machinists have not even heard of. We manufacture gas turbine engines, propulsion as well as APU's. I work in the gear manufacturing department. I also have a lathe at home and build titanium goodies for street bikes on the side.
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    im a mchinist , about 5 years total experience . i work in a job shop in so cal that does mainly ag repair ,trucking ,geo thermal ,canal pump , work for the gypsum plant , and whatever anyone brings in really .
  8. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I'm just graduating from high school Friday, and my second year in an Industrial Manufacturing class. I've got experience on a Haas Mini-mill, a Dyna 3-axis CNC, an Intellitek 3-axis CNC, and a manual mill. I've gained a lot out of the class, and have scholarships to go into the Power Plant Operation course at the local college.
