Any pics of installed sway bar drop brackets?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, Nov 13, 2002.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I need to make some drop brackets for my front sway bar. I am looking for pics of them installed on a similar rig. I am interested in the angle I should make them. I assume a straight 4" spacer might do for my 4" lift but I thought I better check with the pros first.
    Has anybody crawled up under their truck and snapped a picture of them?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I've got a 4" lift, and I never touched/modified my swaybar.
  3. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    Depending on which suspension you have....the swaybar may not be needed.
    /forums/images/graemlins/k5.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I took the swaybar off. I have a 6" lift, and don't need a swaybar, it's pleanty stiff up front without it. Try driving yours with out it and see if you'll even need it.
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    If you install a sway bar disconnect kit, it helps to raise the sway bar back up off the axle and retain its use for on road driving. If you plan on going with a cross over steering setup, you could also add blocks as your speaking of to lower the sway bar from the frame and together they would create enough room.
  6. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Right now it looks like it needs a 1 inch spacer from the frame to the sway bar for it to bolt up. I would guess that the angle would be wrong if I put in a 1 inch spacer.
    I have Rough Country lift spings which feel stiff to me but I have nothing to compare them to. I want to keep the sway bar since this will be a road truck more that a trail truck.
    Anybody familiar with my springs? Can I replace them to get a better ride?
  7. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    not installed but it should give you an idea of what they look like.
    if you still want to keep your sway bar i have these, they offer a 3" drop. send me a PM if you're interested.
    ric
  8. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    welp i don't have pics right now, but i do have a little advice, i found out . i bought the Chevy Drop down Sway Bar Bracket from BDS suspension. and on the phone they mentioned that a fullsize dodge drop down bracket would be better, but what do they know?? "should of listened" needless to say i have a dodge drop down sway bar bracket installed in my blazer now, and in my own opinion i would say it fits 200% better then my chevy one did,
    hope this helps
    Ck1500 /forums/images/graemlins/ears.gif
  9. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks guys.
