any pics or suggestions on mounting a hi-lift jack
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NOT4SHW, Aug 28, 2001.
  1. NOT4SHW
    NOT4SHW Guest
    I just got my hi-lift jack yesterday and I'm looking for a good spot to mount it. I have the stock rear bumper and one of those typical winch bumpers up front. I carry lots of tools, tow straps, chains, shovel 39.5 TSL, etc. If you've got any ideas my ears are open. Well actually my eyes cause I'll be reading them! Ha Ha!
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274,39.5 Boggers for wheeling!
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    hey my friend has his on his topper
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  3. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    You can build a mount it somehow on your winch bumper up front or you can build a bracket on the inside bed and mount it there.
    Or you can get a tire/jack carrier like mine and be done with it. WARNING though: If you leave it in the weather, it will rust! Mine is getting pretty bad.
    Check out my pictures:
    http://www.geocities.com/jmargtx/index.html
  4. NOT4SHW
    NOT4SHW Guest
    Good idea but I wheel topless! Good thing I'm not a chick!
  5. K5Junkie
    Mar 29, 2000
    499
    Gulfport, MS
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Please keep your top on, you are scaring people[​IMG]
  6. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    I don't have any pics, but i mounted mine on the top of my wheel well inside. I mounted a couple of L brackets so they looked like _| |_ , (did that two times) so that the shaft of the hi-lift fits in between. I put the base behind the wheel well hanging down and then ran the shaft forward. I used two bolts to go through the L brackets so that it would hold the hi-lift in place.
    K5 just upgraded to rig status! [​IMG]
  7. NOT4SHW
    NOT4SHW Guest
    Thanks but not for what you said you paid! I love it but not that much! And well lets see it's on a truck it's going to get wet! So I suggest you get some bed liner material and spray it with that and then use the rest on the inside of my K5! Ha Ha!
  8. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    i built a roof rack for my tire and hi-lift ,but it seems kinda top heavy moab this weekend will be it's test
  9. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    I made up a couple of 3" by 4" plates and wleded a 9/32 bolt onto them. On one of the plates I welded a washer part way up the bolt to back against the beam of the jackall. This keeps the top of the jack out as far ar the bottom of the jack. A couple of bolts or heavy screws through the bed side of the blaze, slide the jackall onto the bolts and voila! An under the rail secure jackall mount. You could also drill a hole in the bolt to put a lock on it too.
    Shane
    Never argue with idiots; They will drag you down to their level and beat you up with experience [​IMG]
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    My dad put his on his front brushguard. It works out great.
    Adam
  11. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I bolt mine to the side rail with two bolts through the jack, then made a bracket to hold the back up. It works great. When I rolled my truck 6 times it didnt move a inch. You want to make sure it will stay there no matter what. This was the best place I could think of. I have the 60" Jack and it fits on the rail with no problems.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  12. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    I mounted mine in the inside of my bed using 2" bracketing and wing nuts, stayed dry and even built a lock for when my top is off.
    K-5- because size DOES matter!
  13. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I've got my 60" mounted with a lok-rack on the right side interior wall.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  14. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I mounted mine to the inside of my tail gate. I have pics if anyone wants them.......It fits perfectly and does not interfere with anything.
    <a target="_blank" href=http://www.moabdadc22.alloffroad.com/>http://www.moabdadc22.alloffroad.com/</a>Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
  15. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I put a pic on page 5 of my wesite of the jack mounted. I can give you exact measurements of where to drill the holes for the bolts.....PM me if you want them. And yes, I HERCULINED my tailgate.
  16. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Is the tailgate panel stong enough for the jack?? Has it held up or show any signs of wear bending ??
  17. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I have had it on there for about 2 years. It has been bounced around Moab twice, 21 road twice and rolled once. The only real wear I have seen is from me tightening the nuts too tight. Other than that, it has held up very well.
  18. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    I mounted mine where the back seat USED to be, just got some longer bolts and used the hinge plate holes, leave a 3/4 wrench in the center console and its ready and clean when you need it.
    Veni Sancte Spiritus
    Da Pacem Cordium
    White Knight
  19. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    i zip tide mine to my rolebar look kinda hill billy but it works great ...hahaha
  20. StageZ
    StageZ Registered Member
    Jul 2, 2001
    92
    Los angeles CA
    that just what I did... 5 zip ties, a chain and a lock...
