Any practical way to slow down rusting underbody?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Dec 2, 2000.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I just had my sub painted, it didnt have any rust on the outer surface but the undersides of the panels, the wheel wells and frame all have flaky rust. Has anyone tried to deal with this or do you just let it go? Thanks.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, the key is to get it covered before it is exposed. But as the case so happens to be like the man yof us it that we wait till its too late. The best way to kill rust is to quaranteen it, then lay down the preventative. Even if you stop any future penetrants the old rust will continue to grow. SO you could pull the under panels and the spray the underside with that under coating.
    Don't you buy no ugly truck!
    http://"mccordhouse.freeservers.com"
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Once you get all the rust cleaned off, Coat the bottom with POR 15, and it will prevent future rust. I think you may be able to put it over rust and the rust will stop, but I'm not sure...being from Texas...
    90K5
  4. Can Can
    15,555
    149
    Cochrane, Alberta, Canada
    Actually, Por15 works BEST with a roughed-up rusty surface- the chemical makeup of the product reacts with the rust to create an almost bulletproof coating, at the same time sealing out moisture. I'm going to do my undercarriage when time allows, and I know that a few of the boys around here have used it with much success.
    Check out http://www.Por15.com
  5. shum1
    Oct 8, 2000
    270
    UTAH
    Cool, I happen to have some of that laying around. I gues I'll just scrape off as much as I can then coat it. Do you think I should paint or coat it with undercoating after the por?
  6. Can Can
    15,555
    149
    Just thought I'd mention that Por15 has a shelf life of two years unopened. This is cut down to just six months(I think?) for a previously opened can. So depending on how long you've had it "laying around", you may want to consider buying a new batch.
    I believe you can paint the Por15 once it's cured, but you can buy it in a semi-gloss black that wouldn't really require a topcoat of paint. From what I recall, paint doesn't offer any extra protection unless the coated surface is exposed to the sun.......
  7. Grim-Reaper
    7,385
    Atlanta
    I sand blasted all that crud out from under mine and used a good rust resistant paint. Check your rockers and tail pan. that where rust likes to get eating. do all you can to get rid of it. I have spent the last 2 weekend replacing the tail pan. It was so ate up the back of the truck was folding.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  8. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    move to arizona or texas
    [​IMG] SlyDog [​IMG]
  9. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Dont forget Por15 is a process not just a rust paint. It works best when the area is first degreased and more importantly treated with "metal ready" which actually stops the rust and treats with zinc phosphate.
    Jim
    79jimmy@sprint.ca
  10. Grim-Reaper
    7,385
    Atlanta
    Why would I move to flat old TX? I live 2 hours from Tellico [​IMG] AZ maybe just cause it's closer to MOAB but I like Atlanta just fine and the truck is not from here hence the rust. My 79 is frim here and other than the rockers it's clean as is my 70 LeMans. We don't get much snow here.
    Grim-Reaper
  11. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    <font color=green>2 hours from Tellico</font color=green>! I'm turning green with envy![​IMG]
    Rene
  12. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    Where can POR15 be purchased. I've never seen it around CT.
  13. Woodman89
    Woodman89 Registered Member
    Jul 27, 2000
    60
    New Hampshire
    Here is an easy way out, but it can be messy. Get the bottom of your truck oiled. There is a place around here where you can bring your vehicle in and they will spray the entire underside with used motor oil, getting it inside the rockers and any other opening in the body. Then it needs to sit for a couple days to drip. This works very well in heavily salted areas. This is a good way to halt rust until it can be properly fixed, or a good preventative measure if you dont mind getting messy whenever you work on the underside your truck.
  14. Grim-Reaper
    7,385
    Atlanta
    Sorry to sound like a ECO nut here but HAY THAT CRAP WILL GET INTO THE WATER! Man I do everything I can to keep my vehicle leak free so that I don't polute when water crossing ect. Spraying a couple gallons drain oil on the bottom of your truck is not much better than dumping that oil on the ground next to a street drain. It will make it into the creeks and rivers.
    We have lost the 3 main water crossings at Tellico because of oils and silt being dragged into the water. The ECO nuts have made a big enough stink that bridges are bing built at Fains Ford, Rough water and trails 6 crossing. They actully stood on tha bank watching trucks cross and watched the oil sheen on the water as leaking trucks crossed and used that as amo to force the installation of the bridges to keep those 3 trails open. Dude find a better way. Shoot some rustolium or something that wont wash off.
    Grim-Reaper
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    And one suggestion that no one has mentioned, what about that Ziebart stuff? Take it to the shop and have them Ziebart the entire bottom?
    Of Course POR 15 may work better.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  16. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    I recently heard from a reliable source (Pat Goss of MotorWeek Magazine) that Ziebart actually encourages rust as it keeps everything nice and moist!
    <font color=red>David, '86 K5</font color=red>
  17. mudpuppy89k5
    mudpuppy89k5 Registered Member
    Nov 3, 2000
    44
    Marietta, Ga
    I've been thinking about painting the frame of my '89, not so much due to current rust, but just as insurance against future problems. I was going to use Rustoleum, but after reading the posts, decided to try the POR-15. I just got some of the POR-15 Chassiscoat from a buddy of mine that works at YearOne (www.yearone.com or 1-800-932-7663). He hasn't used it but some of the guys there have and were impressed. They brushed it on and said it worked well.
    POR-15 has a web site at http://www.por-15.com/. Just found it this morning and haven't had time to look at it good.
    I'll post something after I've used the paint.
    John Perry
    http://www.mudpuppy.coloradok5.com/
