Any problem with hooking my Winch up to my starter for power?
Discussion in 'The Garage' started by Silver84k5, Mar 8, 2004.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    And hooking the ground up to the frame?... im Electrically declined... thx for any help....
    By the way thats how i have my MSD hooked up....
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Uhhhh why not just wire it to the battery
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    just get a top and side post battery and hook the truck to the side and the winch to the top /forums/images/graemlins/waytogo.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Exactly , that way your starter has it own dedicated terminal , and so does winch. I don't have a winch but I do run the setup big83 mentions with top and side post, I second his Idea. All accesories are on top and side post is for starter and factory stuff. Besides isnt the battery closest to the winch, less wire equals less resistance. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  5. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    I am wondering about the same thing, I have relocated the battery, it is behind the cab between the frame rails. It would be easier to hook it up to the starter /forums/images/graemlins/thinking.gif
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    the wire that powers your winch requires a larger gage than that of your starter. wire is not that expensive, i would wire them seperately.
    also, a winch should not be utilizing the "common ground" theory
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I would say buy some beefy wire if you have to run all the way back to the back. All that wire=lots o' resistance /forums/images/graemlins/smirk.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think the last time this was discussed, 2/0 was the minimum for that kind of current for that distance.
  9. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i got 2/0 cable... and the battery is mounted behind the passenger seat... but i dont want to run two more thick ass wires threw the bottom of the truck im using 2/0 cable for my battery power and ground, and my engine ground... when i hook up the winch do i need to run only 2/0 cable, or can i splice the Stock winch wires into the 2/0 that i got?
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Why not use a a big junction block from a boat, aircraft, or CUCV? Like the little one on the firewall but a LOT bigger.
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    dunno where to get one /forums/images/graemlins/thinking.gif... what do i do, just mount it on the firewall, run power to it directly from the battery, then run my winch wiers to it????
  12. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Yep, that's it. If you can't find one by the w/e shoot me a PM I *think* I have an extra.
