Any problems going to a 4" lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Apr 29, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Any problems going to a 4\" lift?
    Well the time has come... I'm gonna go from 2.5" lift to an all spring 4" lift on my 84K5. I'm still shopping around for some prices though. My question is what else do I need? I already have extended brake lines,and a steering arm (thanks DuneRunner) .. My rear driveshaft that I have know has been extended for my current 3" lift.. Here is a list of the things I need:
    Shocks
    U Bolts
    4" Springs... anything else?
  2. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    Re: Any problems going to a 4\" lift?
    You'll have to adjust your drag link to level out your steering wheel and maintain steering radius, but that's no big deal.
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    lengthen axle vent tubes
  4. 85HeartBurb
    Jan 10, 2002
    735
    Temecula, south
    extend your axle vent tubes if so equipped!!
  5. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks...For got about those /forums/images/icons/smile.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just go 6" if you're going to go bigger, or install a body lift. I've been where you were--the extra 1.5" isn't worth it.
  7. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    How're you gettin the lift in the back, blocks or shackle flip?
  8. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I went from a 2.5" to a 4" lift. I wont go any higher. I think 4" lift is perfect. It I want bigger tires, I will just get out the sawzall and make them fit. Low center of gravity is a must for rockcrawling.
    Dan
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Maybe think about lowering your transfer case. I needed to on mine. Didn't think I would at only 4 inches, but I did. You might get lucky though. /forums/images/icons/smile.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm using springs or a shackle flip/spring combo for my truck. I'll probably go all spring since I'm going to pull with this truck and I don't want wheel hop.
  11. UseYourBlinker
    Jun 7, 2000
    11,117
    To answer some questions...
    I allready have the t-case dropped
    I am going to use 4" lift springs in the rear
    Just installed a body lift (when I get the 4" springs) That's it! No more height for me.
  12. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I'd go with a shackle flip instead of springs, cheaper and better flex... what more can you ask for.
  13. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    How did you guys drop your t-case? Did you just put some spacers in or did you get some kind of kit? Are you going to have to extend your drivelines?
    Thanks,
    Chris
  14. Mreetz
    Jun 26, 2001
    1,282
    Just take the spacers already on the Tcase and move them to the top of the Tcase, make sense?
  15. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i have a 4in lift, and didnt extend my vents
    where are my vents? how do i do it?
  16. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    i have pics posted on how I dropped my tcase with the factory spacers... pretty simple. I did the job by myself in about 20 mins... and I was going sloooow so as to be super-safe...
    J
  17. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    J, It would have taken me about 20 mins. BUt I was doing it on the driveway and the weight of it moved it around. I had to pull out some rope and wrap it around the rear axel and pull the case to line it up...
  18. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    sounds easy enough!
    Thanks,
  19. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Have you seen that rubber hose that comes off both diffs? that's the vent tube. that is what you extend. You just get a longer hose and tie it up somewhere high. the suspension needs to be able to completely drop without putting any tension on that hose.
