Any real "cons" to swapping a TF350 for a TH700R4?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zeus33rd, Mar 23, 2002.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Any real \"cons\" to swapping a TF350 for a TH700R4?
    Havbe the TH350 now, but I really like the idea of the lower first gear and OD in the 700R4. Heard all the horror stories about the 700 and from what I hear, if ya get the later model, 89-91, then no worries. Of course there is always the TCI/Raptor route. I plan on stayin with the small block- Probably the 330HP GM crate sometime in the future, So I think the strength issues in the 700 won't be a problem. Wanted to here some opinions/input on the idea from people here. /forums/images/icons/laugh.gif
    Also what issues with adapting to a 203 case?
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Re: Any real \"cons\" to swapping a TF350 for a TH700R4?
    Im thinking of doing the same thing on my 73. The only thing that you need to do to the trans is get a shorter tail shaft if you get a trans from a 2wd. Its $170 from advance adapters. it would be another $200 to get it installed. Just get a big trans cooler. You will also have to move back your tansfer case crossmember and maybemodify your drive shafts(lengthen front, shorten rear) because the 700 is about 2" longer than the 350
  3. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    Go for it. Just get a huge woppin' cooler for it. Heat is what destroys them. They're great transmissions.
    -Ben
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It's a can of worms you've just opened up! I was looking into it a while back and was surprised to hear tranny guys tell me NOT to do it. From what they said 350's are not as common as they used to be so parts are getting to be more expensive, they're almost as much to rebuild as a 700r4, the 350 isnt geared the same as a 700, it'll run hotter, gotta get an adapter,blah blah blah. They all said they would help me get it together but I'd end up going back to a 700. I like my 700r4 alot, I had a good builder take care of me. He only charged me $450! Good luck either way you go!!!!
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    He's going the other way
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yeah....RedDwarf is correct. O have the 350 now, Was curious about the 700. /forums/images/icons/laugh.gif
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Chances are any trans you get if its used is gonna need some work. Remember the newest of these trannies is 11 years old, with lots of miles...I'd expect to shell out about $1000-$1500 for a good one
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    OOOOOOPS you're right!!
