any REAR END guys??
Discussion in 'The Garage' started by owen, Feb 23, 2004.
  1. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    ...thought that would get your attention. I need help figuring how to set the pinion depth on my 14ff. Anyone help?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    HOW to set the pinion depth? Add or remove shims... /forums/images/graemlins/confused.gif As for how to tell when it's the proper depth, you have to read the pattern, and for that it's hard to help unless you take pics of your current pattern.
  3. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    the round shim where the pinion unit(?) bolts to the housing? The pattern is just running a little too far out on the ring gear. Might not be enough to sweat. Do I get more shims from GM or where? One more question about backlash- same as 10/12 bolts?
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    IIRC it's .08-.012 on backlash
  5. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    thanks, Brian. forgive me if this is silly, but what is IIRC?
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    I have a bunch of extra shims somewhere, I can try to find them and send them to you. If not, there's lots of other guys on here that probably have stacks of them. IIRC means "If I Remember Correctly"
  7. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    now I get it! Im new to this computer chat thing- and I love it! Sure makes life easier. If you can round up the shims, I would be happy to buy them from you. I suppose if I had a depth gauge I wouldnt have to do all of this guessing. Where would you suggest I get a good one? /forums/images/graemlins/thinking.gif
