Any reason NOT to use Marine bearing grease?
Discussion in 'The Garage' started by Silver84k5, May 7, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i bought some marine grease for my dads boat trailer bearings, and i used it on my TRE's/DRe's, and i was thinkin is there any reason not to use it on my bearings? thx.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    As long as it meet's or exceed's, the spec's, for typical grease, I don't see why not. /forums/images/graemlins/shocked.gif
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    just read the side of the can/tube. it list it's base:(moly, lithium, ....) and it's temp rating, as Don stated, just make sure it matches or exceeds.
  4. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    I dunno...maybe if you're in the Army? /forums/images/graemlins/grin.gif
    j
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    If yer talkin about the blue stuff I have been using it on my K5 fer almost 10yrs. Seams to hold up to the elements just fine. /forums/images/graemlins/thumb.gif
  6. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Yep that's the stuff I use on all my trucks good stuff /forums/images/graemlins/truck.gif
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Yep, I use it too! Can't go wrong with something that repels water out fairly well without breaking down nearly as easily. Just buy the good blue/green stuff as stated.
  8. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    looks like i may try some of that didn't think about it, but it should repel water real good like he said. /forums/images/graemlins/thumb.gif
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    We have 4 grease guns and marine grease is in all of them. The boat, camper and tractors wheel bearings get it and I use is in my ujoints on the blazer. Anything that has a grease zerk around our house most likely has marine grease in it! /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
    Oh I forgot the utility trailer and lawn wagons/wheel barrels. /forums/images/graemlins/deal.gif
    Oh and like everything thing else lube wise... Valvoline. /forums/images/graemlins/grin.gif
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I used Marine grease on all my front wheel bearings and everything else in there when I did the 8 lug swap on my 10 bolt. I have had it in there for 9 months with no problems. I will be using it on basically everything else from now on. Not that I get many water crossings in AZ, but better safe then sorry.
  11. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    I just rebuilt my front D44 and used marine grease. This was only about 2-3 weeks ago though so I dont have much time on the axle with the Marine grease. All I know is when I put the top of the line synthetic grease in my front hubs and bearings it didnt last more than about 3 months and or about 4 wheelin trips through water crossings before my hubs were oozing with nice "Rust" colored muck. I am hoping that marine grease will do much better at holding the water out / not breaking down the grease as quick and therefore not rusting up my hubs.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I had miserable results with the Sta-Lube Marine Grease. Did a worse job than normal wheel bearing grease. This in the front end of a 1700 lbs. 'glas dune buggy, how hard can you load sumthin like that ?
    Now I use Redline CV joint grease for all wheelbearings and Red-I for stuff like driveshafts. The CV grease repells water better than the so-called 'Marine Grease' did, and it's rated for a much higher PV.
