Any reason this lift kit wouldn't work?
Discussion in 'The Garage' started by Tuff84blaze, May 8, 2004.
  1. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    Any reason this lift kit wouldn\'t work?
    I am looking for a 1990 3/4 ton suburban, it has 14 bolt sf rear and 8 lug 10 bolt front. What might not fit I was thinking I might have problems with the rear U-bolts or spring bushings holes for the shackels. Ez ride lift
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: Any reason this lift kit wouldn\'t work?
    1) You need to get the 56" rear springs
    2) The rear u-bolts need to be for a 14 bolt SF...not sure on the diameter of those, so someone else will have to let you know. If you order the kit like you're ordering for an '86 3/4 ton pickup, everything should be right.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    He might or might not need 56" springs. While most 3/4 tons have them, I've seen 3/4 tons with 52s and 1/2 tons with 56s and no real reason why.
    14 bolt SF tubes are 3 3/8" just like a 14 bolt full floater.
  4. heavy4x4
    Aug 28, 2002
    3,270
    True, but with it being a suburban, I'd say there's a 90% chance of having the 56's.
    Best thing to do is check though. Go stick your head in the rear wheelwell with a tape measure and measure from bolt-to-bolt along the top spring.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My point was check first, then order the right ones the first time. I agree with you though, most likely 56s, but springs are expensive to ship and ship back so he might as well make sure to get the correct ones the first time.
  6. Tuff84blaze
    May 12, 2000
    119
    They are 56" rear springs, thanks for the input. /forums/images/graemlins/thumb.gif
