Any reason why I can't get a hose down the filler neck?
Discussion in 'The Garage' started by jfaulk, Feb 17, 2007.
  1. jfaulk
    jfaulk Registered Member
    Dec 3, 2006
    60
    NC
    I am trying to syphon out all of the old go juice and I can only get a hose about a foot and a half or so down the filler neck and then it won't go any further. Any ideas? :confused: Thanks
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    theres a hard 90 into the top of the tank. twist the hose as you push, it should pop down.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    What year of vehicle, i know some of the later models, some older as well, they put a ping pong type ball in there to prevent anybody from siphoning fuel, fuel will flow past it, just prevent a hose from getting to the fuel :crazy:
  4. jfaulk
    Dec 3, 2006
    60
    NC
    It's an 86 K5. If it does have one of those ping pong ball deals in it, what's the best way to get the fuel out? I really don't want to drop the tank. Is it possible to disconnect the fuel send line and somehow syphon from there? Thanks
  5. Jrgunn5150
    Jrgunn5150 1/2 ton status
    Nov 26, 2005
    232
    Cleveland, Oh
    Can't you pull the filler neck on a Blazer without pulling the tank?
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    it is just the 90* bend.
    my syphone has a brass end on it with a glass bead, so you shake it to start it.
    that was a bitch beond all other to get in there, probably took me 20 min. with that one.
  7. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Maybe I'm lazy, but a cheap autozone electric fuel pump hooked to the line on the frame works wonders, and leaves me to do more meaningfull tasks.
  8. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
  9. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Treat it like it's her first time and just jam it down in there, it'll go...
    spit on it if ya have to:doah:
  10. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    arnt you the charmer.
    dont listen to him next he will be telling you to poke it in the exhaust!!!
    :d
  11. 4xcrazy
    Oct 31, 2003
    9,472
    5
    :haha: :doah: :D :haha:
  12. garlicbreath
    May 17, 2003
    1,136
    Denver
    Also, if you can't get the hose to go all the way in, I like to use my lighter to see what the blockage is.
  13. jfaulk
    Dec 3, 2006
    60
    NC
    That's a good idea. While I'm at it, might as well put my johnson in a vice and tighten it down then smack it with a bfh.
  14. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah some people try that with mixed results.
    If i were to i would give the said hootest a good coating of herculiner first this will protect it from scuffs :waytogo:
  15. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Thank goodness this thread didn't get off track.
  16. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    we covered the bases first :dunno:
  17. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    [​IMG] this is the best ever if only i had something to say but i just cant stop laughing but yeah if you cant hit the hole the first time take out some of the neck so you can get a better aim at the hole and then ram it in there then suck on it for awhile till it starts flowin then spit a couple times to get the taste out your mouth then put the neck back on and some good go juice and your set all in a good days work [​IMG]
