Any reason why I can't use a diaphram type clutch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84_Chevy_K10, Jun 16, 2002.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Any reason why I can\'t use a diaphram type clutch?
    Is there any reason why I can't use a diaphram type clutch where the three finger style once was?
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Re: Any reason why I can\'t use a diaphram type clutch?
    No reason at all why you couldn't. Your leg will thank you. /forums/images/icons/wink.gif
    Rene
  3. dyeager535
    26,979
    As Rene said, your leg will thank you : )
    My dads got a 3 finger on his truck, and I've got diaphram. Mine kicks the crap out of his, in both feel and ease of use. There was an article in Car Craft or 4wheeling or something about clutches in the past year, an it broke down all the different types of clutches, and their use. After reading it, I still felt good about using a Diaphram style, so obviously there aren't any serious flaws in the design.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I know my leg will thank me. That's why I was hoping the flywheel was the same either way. My friends clutches are HARD! I definitely didn't want that.
    I have a used clutch and I think I'm out of money and I was considering using it. /forums/images/icons/mad.gif I hope I'm not.
    Thanks.
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    I have the Borg & Beck (3 finger)...I hate driving in traffic with my truck because of it. /forums/images/icons/crazy.gif
    Some dork at the parts place I bought my clutch convinced me to go with the Borg & Beck over the diaphram clutch a few years ago...said it was superior. I personally don't believe it and I will go with a diaphram clutch next.
    Rene
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Damn...I was gonna order a Zoom clutch from Summit, but my local NAPA has a lifetime warranty diaphram for $135!
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The three finger clutch has a higher pressure rating and can hold up better to high horspower or racing situations. When I had a manual, I ran a weighted diaphram clutch that helped to make up for this but I still smoked it good at every mud race (Letting it slip at 5 grand was hard on it). I think that was due to the style of driving than the clutch itself. For 90% of applications a diaphram clutch should be fine.
  8. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I would run a diaphram clutch. Much nicer to use.
    Some thing to note about the 2 types; with a finger clutch, the further you push the clutch in the harder you have to push. With a diaphram, the hardest part of the travel (where you have to push the hardest) is in the middle of the travel; I have a very stiff diaphram clutch in my truck (with brass/ceramic pucks as opposed to a regular organic lining), and if you're not used to it it kind of kicks back at you once you get it half way out. However most diaphram clutches are easy enough to push that you don't notice the effect.
    Pete
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I wouldnt spend extra for a Zoom(actually I did)
    not alot of mystery to a truck clutch
    the Napa or Luk will be fine for most
  10. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I like my three finger clutch because nobody else whats to drive it . The old diaphram was a lot easier on the leg.
  11. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    In my experience, the diaphram pressure plates do not take well to being submerged in mud (they quit working), whereas the three finger style are not affected as badly by it. Just something I have observed, that you may or may not need to worry about /forums/images/icons/smile.gif.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well I'm only 125 lbs. so I refuse to have the caveman clutch even if it is a little better. I went and bought the Diaphram clutch today and got my flywheel turned. $150 for the clutch kit at Napa, brand new, lifetime warranty.
  13. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    In the past I used a three finger clutch, But somewhere I read that using such a high presser clutch mite put undo wear on the main bearings. So now I would go with a daiphram and I know my leg would like it.
    Eric
