Any suggestions for a cam??
Discussion in 'The Garage' started by Tshane, Jun 20, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    I want a cam that has a lot of torque from low rpms and wont fall on its face at like 3 grand. The lift has to be under .5 because i'm using vortex heads. /forums/images/graemlins/truck.gif
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    best bet is to call comp cams and ask them. They are really good about helping people out. Every time I call them they are more than happy to look up numbers or let me know what they recommend.
    Since they either bought or were bought by Crane cams they are pretty much the experts on the subject. You tell them what you want and they will tell you the cam part numbers that will get you what you need. guaranteed. /forums/images/graemlins/thumb.gif
  3. dyeager535
    26,975
    FWIW I see Crane is offering $20 off on their powermax cams http://www.cranecams.com/
    Not sure if they are the "style" you would need, but $20 doesn't hurt!
    BTW, I'm running .452" max lift on my Vortecs, and I've got the MINIMUM retainer to seal clearance recommended. I'd either wait until you get the heads and can mock them up to check this, or do some testing to figure it out now. I know people have run .480" max lift on these heads, but I simply wouldn't do it if I planned on keeping the motor.
    Also you better talk to the cam people...getting springs with the right pressure for higher lift cams that fit the Vortecs is difficult. Stock Vortec springs are something like 90lb springs, my roller cam (roller cams being what Vortec heads were designed for BTW) required somewhere around 112lb springs.
