any suggestions
Discussion in 'The Garage' started by nartow, Jan 24, 2005.
  1. nartow
    nartow Registered Member
    Jan 22, 2005
    14
    ma
    i bought a 86 chevy c10 with d44 front and 14b rear and 6'' supenion spings all around and 3'' body i got it because it was only $500 but it was in a front end crash so there is no front end on it or motor,t case ,trany and when the guy was running it he said that he would blow front hubs if there where alunima if steel would sheer the hub bolts so i got it home and took the front diff cover off and the gears were 4-11 then the rear was 4-10 so would this be a proplem any way i'm swiching the rear gears to mach the front any sugestion for doing that
    ps sorry about the spelling
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    1) Was it converted into a 4wd? C series trucks are 2wd.
    2) Having one extra tooth will not make a difference. 4.11's and 4.10's are basically the same thing.
  3. nartow
    Jan 22, 2005
    14
    ma
    sorry its a k10
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You are allowed like 5 percent on gearing front to rear to allow for tire wear etc , some axles only have 4.10's , some 4.11's available :k5: :k5:
  5. nartow
    Jan 22, 2005
    14
    ma
    so what could be the problem with the front hubs blowing or sheering bolts
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    With that much lift on it, I would have to say he was running too large of a tire on an axle that isn't up to the task. General rule of thumb for 1/2 ton axles is 35's MAX on an unmodified setup, with a light right foot.
