ANY THOUGHTS ON THESE X-OVER KNUCKLES??
Discussion in 'The Garage' started by tree_entz, Oct 5, 2004.
  1. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    OFFROADUNLIMITED
    Finally planning on doing a blazzzzer build-up and will
    need x-over for the front spring swap.
    you guys think the knuckle will hold up? any1 run these?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those are for the newer Ford axles, mainly the Super Duties. Won't fit or work for anything GM D60's. Those arms on the ORU site are the ball-joint style knuckles.
  3. tree_entz
    May 4, 2004
    141
    N. Vermont
    hmmm... i dunno bout that, they've got listings for chevy 10bs and d44s
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    your better off going down to the junk yard. Are finding one in the for sale section on this board.
  5. tree_entz
    May 4, 2004
    141
    N. Vermont
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The one shown is for a 50, but I belive hes referring to the 10b and 44 knuckles they make.
    I think ORU is rather pricey, you can go to the junkyard like as stated above. Or just hold off if you are going to later swap in a 60.
  7. tree_entz
    May 4, 2004
    141
    N. Vermont
    all i'm thinking is that you gotta find the flat top knuckle,
    send it out, get it back and even then it's not one piece.
    a 2wd box is easy to find of course.
    but I guess what I really want to know is the one-piece knuckle stronger? you also have the option of added height on some for larger lifts too.
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Well it is cast. That isn't horrible but if it breaks you will not be able to fix it. There is also no option for hi-steer if you ever wanted to move in that direction. It works, I don't know of anybody running that style on the trail though. For the price for one knuckle you can do the whole x-over like everybody else and have parts that will be easier to find if you have problems.
  9. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    838
    Pinckney, MI
    Whoa thats pricy. I would junkyard and home brew it!
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you realize they want $600 dollars for that crap right? You would feel horrible if you spent $600 on crossover on a 1/2 ton axle. I mean, maybe all together. I usually sell the flattops I get for $100 a piece. $50 to get them machined I believe. $100 for a steering arm. Thats $250 for a knuckle they are charging $600 for. You could get your drag link,($95) and pitman arm($80) AND STILL not pay as much as that.
  11. tree_entz
    May 4, 2004
    141
    N. Vermont
    Thanks for the thoughts... wanted to see what everyone thought, and when the time comes for the reasons outlined here, i'll probably have an ORD setup or something similar
    BUT....FYI
    the $600 is for everything but the 2wd steering box /forums/images/graemlins/deal.gif
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    BUT....FYI
    Are you positive? When we did SAS on my buddies truck the drag link, ends, pitman arm and steering arm were something like $600. And the drag link was screwed up. Thats what I paid for my Hi steer and crossover from Sky, and MUCH better quality parts.
    So I dont see how pitman arm, drag link, ends, hardware AND a macined knuckle can cost the same.
  13. tree_entz
    May 4, 2004
    141
    N. Vermont
    All of ORU's Crossover Steering Kits include: pitman arm, drag link, tie rod ends, and jam nuts.
    Chevrolet NOTE: All of the Chevy kits require 2WD steering box of same year as vehicle.
    This section covers all Chevy's from 1968-1987, and 1988-1991 Blazers and Suburbans.
  14. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Just by looking at how high up the drag link is, I would think that unless you are running 15 inches of lift that drag link will make contact with the engine crossmember which then you will have to re bend or have the draglink bent ( To this -\_/- ) to clear the crossmember...
  15. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes exactly, no mention of a steering arm or machined knuckle.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That looks scary as hell to me anyway!!!
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Why? /forums/images/graemlins/confused.gif
  18. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I like them......
