Any tricks in replacing the wiper motor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Nov 19, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Gonna replace the wiper motor on my 84 today,any tricks or things I should look out for? Thanks in advance /forums/images/graemlins/thumb.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    1st trick: Unplug the motor before you do anything! There is always power to the wiper motor. If you happen to move it so that the auto-park switch closes, it will start running to go back to the park position. If you happen to have a finger in the mechanism when this happens, you'll be in a world of hurt. /forums/images/graemlins/shocked.gif /forums/images/graemlins/frown.gif
    2nd trick: The very last step is to plug in the power to the new motor. See warning above. /forums/images/graemlins/wink.gif
  3. Exactly what he said !! I need to change out mine in the jimmy soon. Also think it needs some gromets and such so the linkage will work smooth too !
  4. Exactly what he said !! I need to change out mine in the jimmy soon. Also think it needs some gromets, bushings and such so the linkage will work smooth too !
  5. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    To disconnect the actuall pump from the wiper arm link, I moved the wipers in the UP positions.
  6. UseYourBlinker
    Jun 7, 2000
    11,117
    Well I put the new re-build motor in about 10 mins. Went smooth. /forums/images/graemlins/thumb.gif
