Any Tricks To Easily Cleaning A Q-Jets Exterior?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Jan 12, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've got an early Q-Jet that I'd like to "brighten" up. I was thinking of using aluminum rim cleaner, it etches the aluminum to a shiny finish but I'm a bit worried about the gasket material and don't wish to disassemble it. Anyone found any tricky ways of bringing back the original finish without a full teardown? Oh, toothbrush and soap took the dirt off but the finish is still dull and aged. Thanks.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://24.55.50.76:81/k5/> Pictures</a>
  2. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    a rotary wire brush on a die grinder works miracles!!! Did this on a Holley 3310 a few weeks ago and it looks just like the factory polished models!!
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'll give that a shot. I'm not afraid of a little work.
  4. dyeager535
    26,979
    Paint thinner and a stiff brush.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    dull and aged is cool !
    always gets me home K10
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm going to try the paint thinner with the rotary wire brush bit. The bit alone was working nicely but I might be able to get a little more of it off a little quicker with the paint thinner.
    Dirty just wont do on this one Andy - check out the "complete" pics of the 415.. its coming together sooo well and has to be the closest tolerance engine I've ever built. Which is odd because its not exactly the wildest engine I've ever built... but it will get there.
    P.S - You better make it to Ocatillo on the 3rd - I'm droppin the 415 in this weekend!
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    awesome man , and u put my vid in yer Finally updated site hehehe. 3rd of what ? ive got a cracked frame and a fractured left hand index finger from work so i cant fix it or anything !!
    :*( i can still drive i just cant really do anything else ! " insert coarse language here "
  8. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I like Seafoam.... it removes the gunk (and if you get it inside it cleans it too!)... I also use a stiff nylon brish when I scrub.....
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    Stop Global Whining
    I'm in shape.... round is a shape......
  9. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Cacked frame - broken index finger? WTF! Whats been going on? You gotta fill me in on this one!
  10. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    oh this last thursday i was chiseling at work and the guy i had holding the part shifted it slightly and i smacked my hand goodnhard and fractured my index finger above the first joint ....eh sux ... no pain reallly and my fram finally cracked at the steering box (hope you are happy m.j.) even with the ORD brace ahem cough cough , wasnt there a policy that if it cracked with the brace u got the weld on kit for free ?? ;-)
  11. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Nice.. well at least both are fixable. I hear ORD makes a finger brace but it was originally manufactured to fix the ever so breaking middle finger from breaking loose and awarding other drivers, you might be able to adapt it! Oh, and a broken finger is no reason to miss the next run in Ocatillo wells, ahem. Got me worried about not having a steering brace though!!!
  12. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i have a steering brace , thats probly all thats holding the box to the frame almost ....and my driveline still needs work and and and and hahaha .....oh and no both arnt fixable , i can weld and reiforce my frame , i dont think plaster will help much tho ....
    always gets me home K10<P ID="edit"><FONT class="small">Edited by K10ANDYKHAMNIC on 01/15/02 01:34 PM.</FONT></P>
