Any tricks to removing/replacing the rear window in a '74 and '82 PU?
Discussion in 'The Garage' started by dontoe, Oct 3, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I wanna install the rear sliding glass from a '82 PU to a '74 PU. Any info would be appreciated!! :o
  2. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    It's really easy. I was scared at first too, I could see myself breaking some glass. But I just took a screwdriver / puty knife and pushed the weather stripping out. I was inside the truck and pushed the weather stripping towards the outside (back of the truck). Then just did the opposite to install the slider. I don't know is this is the "proper" method, but it worked for me.
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    yup...
    It's harder to remove the windows, than put them back in,in my opinion..
    I just did like B to C said--push out the rubber and get it started,and spray it with soapy water to make it easier to slide out..Ivory Liquid dishwashing soap works great..you'll have to push on the glass some to get it to come out of the rubber..be gentle!..
    I use a peice of speaker wire or thin nylon cord (like a lawnmower pull starter rope) wrapped around the inner groove of the window gasket to pull the rubber back in place ,after setting the bottom of it onto the cab's pinchweld,and getting it started..having 2 sets of hands can help..:crazy:
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    2 sets of hands are a must.
    solid windows are VERY delicate.
    as for lubrication, use aerosol window cleaner, and soak it good. wont leave a residue like the soap will.
  5. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Didn't know how similar the windshield and sliding rear would be, I searched and read a lot............nothing I found dealt with the rear. Thanks though............I'll use soapy water and get someone to help hold it! :laugh:
