Any tricks to taking out slider windows?
Discussion in 'The Garage' started by CK5, Mar 4, 2004.
  1. CK5
    May 19, 1999
    21,622
    701
    CO
    Need to pull out the sliding rear windows from my hard top before I cut it up and throw it in the trash, any tricks?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    B...R...I...C...K... /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I also forgot another one, maybe a little faster: H...A...M...M...E...R... /forums/images/graemlins/whistling.gif /forums/images/graemlins/histerical.gif
  4. CK5
    May 19, 1999
    21,622
    701
    CO
    No, I want to save the slider windows, the top will get real friendly with Mr. sawzall though. /forums/images/graemlins/hack.gif
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    No tricks really...
    I just work the weatherstrip with a couple putty knives..
    from the inside of the glass..
    Get some help..so the glass doesn't hit the ground.. /forums/images/graemlins/whistling.gif
  6. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    They're easy to take out Steve...it's putting them back in that is a PITA. There is a little metal tab somewhere around the middle of the outer rubber seal along the bottom, pry it off. Then pull the rubber 'cord' out of the seal all the way around the glass. You should be able to gently pry the glass out once that cord is out.
    Rene
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, not to difficult to get out.
    Hmm, sounds like you are about to do what my son and I are planning for his topper. Of course at the rate he is putting time into it, we won't get around to it till sometime around mid 2010 or so. /forums/images/graemlins/doah.gif
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, what Rene said. Once you remove that center strip from the weatherseal then it's pretty easy to take the window out. /forums/images/graemlins/thumb.gif
  9. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    If you are cutting the top up anyway then why not just cut close up to the rubber top, bottom, front and rear and break the fiberglass out from around the rubber, that way you dont have to take anything apart.
    That is what I did with my top and it was super easy.
  10. CK5
    May 19, 1999
    21,622
    701
    CO
    Thats what I think I will do because they are fused in there pretty good.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If you don't care about the gasket, you can cut the lip off after removing the bead. Then it pretty much just falls out...
