Any trouble with red tops?
Discussion in 'The Garage' started by 454k30, Mar 11, 2007.
  1. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I have a red top optima, purchased last july. I love the starting power that this thing has but I have concern. That concern is that this battery doesnt seem to hold a charge well. I can have it fully charged disconnected and a week later it is down to 10 volts and cant crank my 454. Maybe I am being picky but I thought these optimas were supposed hold a charge for a very long time. Has anyone else experienced these problems?
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    My redtop holds charge for literally months. Pull it out of a car, throw it on the floor in the shop, 3 months later backhoe battery died, put the redtop in the backhoe, started right up.
  3. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    Optima really seems to be screwing the pooch with their AGM's...
    Best battery tech out there, we love the AGM's we run in the boats.. No funky charging parameters like the gels.. Tho they weigh a ton...
    Apparently Optima may still be having the same issue they had a few years ago with changing out some of their materials...
    You guys should really consider looking at marine batteries next time your in the market for an AGM style battery.. We've had no issues with the ones we've been installing... I'll have to peek in the battery room tuesday and see what brand it is we're selling...
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    only problem i've ever seen with a red top is when they go dead, they never recharge good. if you can keep it from going dead, they will last for years, but as soon as it has to be recharged, the life of it just got flushed.
  5. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    Same problem. You have a draw on your battery when the key is off. I am currently troubleshooting the same problem. If you come up with a solution or leads please post up!
  6. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    he says "disconnected"
    have you done the testlight in line method of checking? finding draws is a very simple procedure...
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    many guys say when you discharge an optima fully, it will never fully recharge properly. With that said, I have fully discharged my red top MANY times over the past few years, and the damn thing still tests out with more Cold Cranking Amps than it is rated for (testing with our equipment at work).
  8. uberbeans
    May 14, 2004
    564
    Doah! Weird how it loses charge when disconnected. I figure that something I have installed is wrong (I suspect my MSD 6AL). I am about to install Edlebrock pro-jection and will do the test light stuff next. The truck is so simple, it can't be that hard to find. My 6AL is a dealer demo that I got for free years ago from a friend. I wonder if they have something different in them to prevent the from being used on a vehicle. It's funny it even says on it "not for sale". What do you think? (sorry to hijack).
  9. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    I had a mix of problems with my truck and a redtop. I had some bad wiring, once I fixed that, I still had issues with my redtop. took it to auto store and they said it had a cell shorted. Not sure what caused it, but I traded it underwarranty and got a yellow top. I havent had any issues lately. I heard rumor that there have been some bad redtops out there.
  10. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    all batteries will lose SOME charge from sitting.. how they are stored, maintained is the important factor... A well maintained battery in storage's charge loss is pretty negligable if occasionally trickle charged...
    I'd doubt the 6A is any different, but stranger things have happened.. companies do occasionally sabotage demo items... but usually just so they don't work...
    back to the AGM's now... :wink1:
  11. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I had a red top that sat in the cold for 3 months and died. The battery never held a charge after that. It was under warranty so I got a new one. The guy at the counter said that was the third red top that month.
    I have had this one ever since (4years) and it works great so far.
  12. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    forgive my ignorance, what does AGM stand for?
  13. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Absorbed Glass Mat. It's a type of sealed lead-acid battery technology. Anyway, I have found that charging is somewhat critical with an Optima. If it is discharged it needs to be charged at a fairly slow rate (10A or less) in order to fully accept a charge. Temp is also important - a cold battery doesn't charge well.
