any way to fix sway on a 67'
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 1967k10, Dec 20, 2006.
  1. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    I need to get rid of the front end sway on my 67'. I'm running 6" Alcan's,custom hangers,and longer shackles. I have close to 10" of lift. Truck is fine except cornering at speeds over 30mph and it's not stable :eek1:. Can I run some type of z-link from the frame on one side to the diff on the other :confused: ?
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Yes.
    By the way, you mentioned having a 6" spring with 10" of lift. Where is the rest coming from??? Longer shackles don't add THAT much.
    I'd like to see a pic, but a panhard bar would certainly help if the springs are trying to puke-out sideways on you (which they might be). If the problem is just really soft springs, then a swaybar setup with long drop arms would be the ticket.
    The panhard bar will probably help with deathwobble too, if that's an issue for you.
    Pics!
  3. 1967k10
    Nov 21, 2005
    1,728
    I may have to send them to you to post. My dial-up won't seem to let me post up here :mad: . I have custom front hangers as well.
  4. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    you can send pic to me in e-mail and i can post it on the board for you. If you'd like.
  5. 1967k10
    Nov 21, 2005
    1,728
    I send a couple your way. Thanks
  6. 1967k10
    Nov 21, 2005
    1,728
