any way to stop a motor from knocking?
Discussion in 'The Garage' started by thezentree, Aug 15, 2004.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    my 97 vortec 350 knocks, and i'd like it to stop. is there anything short of a rebuild that would help this out?
    and almost as importantly, what exactly makes a motor knock? pinging is predetonation (correct me if im wrong), so what is knock?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    knock=rod knocking on the crank=needs new bearing.
    you can just pull it apart and put new bearings and rings in it. northern sells a rering kit for this.
  3. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Higher octane fuel or boosters will prevent ignition knocking. A rebuild will stop the rotating assemble knocking.
  4. thezentree
    Sep 19, 2003
    7,198
    NC
    i switched to a higher octane fuel to stop pinging, since the local stealership doesnt know their ass from a hole in the ground and screwed something up. but i digress....
    i'll take one new motor, please!
  5. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    No hijacking here, but I would also like to know what leads to the conditions that cause an engine to knock. Just lack of oil changes...? My 3.8 in my Cougar knocks more than a Jehovas Witness...
    Damn furds.
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    There are many different kinds of knocks.
    I have heard fuel pump pushrods knock in a SBC. The "new" generation Vortecs have piston slap that in some trucks are louder than diesels /forums/images/graemlins/eek.gif(a condition deemed normal by the general /forums/images/graemlins/shame.gif) Also a cracked flex plate can sound like a knock. To properly pin point a sound like a konck you would need to find the area/conditions when it will appear.
    Usually a low pitched hollow sounding knock rythmic with engine RPM would indicate a rod possibly main bearing failure. But there are so many things that it can be its hard to say what caused it and how to fix it...
  7. thezentree
    Sep 19, 2003
    7,198
    NC
    Damn furds.
    in my case, its probably water intrusion from the time i almost hydrolocked it /forums/images/graemlins/doah.gif
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Turn it off? /forums/images/graemlins/dunno.gif
    Sorry.
  9. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    So is there a way to hunt a knock down in an engine, and actually find out where it is without completely stripping it?
    /forums/images/graemlins/confused.gif
  10. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    You can use a mechanics stethoscope(looks like the doctors!)to help pinpoint the source of the noise,and by pulling the plug wires off one cylinder at a time it will usually deaden or reduce a rod or main bearing knock in that cylinder,wrist pin or piston noises usually get louder when the plug wires on that cylinder are pulled--be carful because the HEI ignition coil can put out up to 50,000 volts,use insulated pliers make for that purpose,or you'll get zapped for sure.Is your motor rapping(like a rod knock?)or is it just "pinging" like when you have cheap gas and overadvanced timing?. /forums/images/graemlins/crazy.gif
  11. thezentree
    Sep 19, 2003
    7,198
    NC
    well, it does both, but it doesnt ping hardly at all anymore because i run 89 octane fuel. im thinking that i got water in a rod bearing and warped it or something
  12. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    try any lucas??
  13. thezentree
    Sep 19, 2003
    7,198
    NC
    yea, it helped, and oil pressure is up about 10psi when at operating temps and idling, but its still knocking a little bit
