anybody actuate a 241 with a cable
Discussion in 'The Garage' started by TorkDSR, Sep 2, 2004.
  1. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i want to actuate my 241 with a cable. seen too many broblems with linkage getting knocked around.
    how much force can a tranny shift cable push? im not worried about the pulling part.
    right now i just left the shifter on 4lo and that should be fine for a while.
    i think i can get some pto shift cables from work... maybe ill start playing, but i was just looking for ideas
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I've been wanting to do this as well. I may take a crack at it when I do the new t case. Rather than cutting a whole for the new shifter on the driver side. I don't see why you couldn't do it. Its not hard to actuate by hand(same as an auto trans i think). Would be nice for tight quarters like on a buggy to be able to mount in a remote spot.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I may end up going this route as well. Just to eliminate bind and that sort of thing. Plus I can put the shifter in the hole that is already in the floor rather than cut a new one.
  4. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    its actually pretty tough to move... its all i can to to shift her with a stubby wrench, thats my concern.
    well, lets pioneer this and write an article
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    what I'm thinking. Don't think there would be anything wrong with a larger(leverage) arm on it. ANd some type of thick cable, gonna have to see where to source that.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I don't think it would be difficult to do. Mine is to far from being in to do too much with it but I could fab some stuff up for us. Extended lever or cable mounts.
  7. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Use a tranny shift cable from a front wheel drive car with a stick (like a toyota camrey) or somthing like that. They use big beefy cables that are designed to push and pull. /forums/images/graemlins/thinking.gif
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    On pushbutton 4wd vehicles they use a small electric motor with gear reduction to shift it. I'd probably just use a really large disc to rotate the selector shaft.
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    You could use 2 cables, in a "push-pull" configuration.
  10. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    It shouldn't be too hard to do.
    A lot of the transfer case / transmission functions on the HEMTT I drove were cable actuated.
    As long as the cable is adequatly lubed there shouldn't be much binding ever and with an appropriate lever on the case side it should work well.
    I've been tossing the idea around in my head for awhile too w/ my 208 when I build a custom console.
    The puch pull idea sounds like it will give a bit better force too.
  11. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    TTT
    Anyone done this?
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    just wondering if anyone has done this yet. id like to do it also.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    nah none of us ever did a thing about it as far as I know.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
