Anybody break a 241?
Discussion in 'The Garage' started by Sandman, Jun 11, 2003.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thinking about dunping the TH350/205 for a 700r4/241. Convert the 241 to a fixed output and a bigger chain. Would be a good way to get a decent crawl without adding more weight. But how strong are they?
    Present crawl is like 50:1
    That combo would give me about 85:1
    Hmmmm. /forums/images/graemlins/thinking.gif
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    sorry, no help, but i know the 241 is the case i'm going after when my "weak" 208 goes.
    /forums/images/graemlins/thumb.gif
  3. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    The only ones that I've seen break are the ones that have incorrect legth driveshafts (mostly the front) and basically push on the transfer case and break both outer halves of the transfercase.
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I think the common view is that the internals are strong but the aluminum outer is a danger point.
    So clock it and armor it and you will be golden. Mine has proven to be great - high mileage, some good wheelin, etc....
    But I still have the stock 3fiddy /forums/images/graemlins/smirk.gif
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I might have to think about that swap then. I'm getting out of the mud so I plan on pulling the 454 wich is way overkill for maybe a vortec 350 and then the lighter transfercase. I am hoping that this will shed some pounds. I am sitting at around 5400 now with the doors off but the tailgate on. My goal is too get below 5000 with 40" tires and the 1 ton stuff.
  6. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    454 overkill, I didnt know you could go overkill w/ horsepower, Ill take that 454 of your hands
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I'll put it this way, Dodge put them behind the Cummins...I think it's strong enough
  8. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I was going to mention that and then saw your response. /forums/images/graemlins/smile.gif /forums/images/graemlins/thumb.gif
    As far as breaking mine...nope. But Polaris bent the output shaft of hers. Don't know how, but it in turn busted the aluminum tailshaft piece. /forums/images/graemlins/shocked.gif
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    That reminds me - plan on a SYE kit.
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Its going back into my '71 SS Chevelle. /forums/images/graemlins/grin.gif
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Is that the rear yoke kit? I was going to do that one. Maybe upgrade to a 1.5" chain while I was at it.
  12. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yep, SYE = Slip Yoke Eliminator /forums/images/graemlins/thumb.gif
  13. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    yea clock the 241 up, keep it protected and put the SYE kit on it and beat on it!!
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    How do you clock one of these things? I've never had a close up look at one.
  15. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This guy makes/has a clocking ring designed for a 231. He claims it will work on the 241, but I couldn't get pictures of the 241 ring from him. He claims to have a sleeve that is "pressed" on the output shaft of the tranny to extend its length to make up for the clocking spacer.
    http://www.cox-internet.com/go2guyengineering/
    I pmed him back and forth a few times, but I couldn't get enough info to make the purchase...
