Anybody do a 52" front spring conversion for 8" lift?
Discussion in 'The Garage' started by 4GUNZ4X4Z, Dec 25, 2004.
  1. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Just like it says. I want to do the 52" conversion up front, but instead of going with a stock spring, I was thinking of going with a 4" lift spring to give me an overall of 8"'s of lift up front. Any thoughts on this from somebody that has actually done the conversion? Has anyone done what I'm planning on doing with a 2" or taller spring? Anyone, ....Anyone?
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I did it with a 4" rear spring. No idea how much lift I've got, but if you want a dimension from say the bumpstop the axle tube i could og measure it. My truck wasn't stock before the lift so I don't have a point of reference.
    :xmas:
  3. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Yes, please that would be great!!! Any angle problems? Are you clearing your 42's ok? Thats what I have except with a 4" lift, need/want to go a lil taller.
  4. dhdescender
    Aug 10, 2002
    628
    Not with 1410 Driveshafts.
    That said, I have dual t cases, so my front shaft is 39" long.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have BDS 4" rear 52's up front. I also made my own front/rear spring mounts and have a 1" Z-rate moving my axel foward 1". I have a total of 9 1/2" lift. Take away the custom componants and I would have 7 1/2. I removed the overload spring and I also have a steel headed Big block. with a small block, you should see about 8". I have so much more flex in the front now, i had to get custom made front brake hoses and need a new front shaft!! It seperates the splines when I flex it!! YAHOO!!
  6. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Bablazer73,
    So with the zero rate and the 52's how far did your axle move forward?
  7. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Did you guys use a 7 1/4 shackle? Eye to eye, right.
    dhdescender,
    Could you measure the distance from the frame directly to the leaf, in front of the spring plate?
  8. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I dont understand where you are going with the above statement?
    I am thinking of trying to get 8 inches of total lift out of the 52s myself.
    Anyone else hace some more info on this subject?
  9. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    with the springs alone, The axel didn't move. I used the Z-Rate to move axel foward the 1".
  10. dhdescender
    Aug 10, 2002
    628
    How about to the axle tube, diferent brand of leaves +/- and an overload will change it.
    I'll do it next time im at the shop. PM me if i forget.
