Anybody do ball joints on front 10 bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 Shortbox, May 23, 2002.
  1. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    Like it says, how bad of a job is it. I know that everything from the spindles out have to come off including the axle shafts, but how do you separate the knuckle ( I think that is the term for it) from the axle. I have a ball joint separator but was wondering how to do it with a ball joint on the top and bottom. Is it possible to just beat down on the knuckle? Thanks for the info.
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    I just did mine about a month ago. You have the right idea, just beat the seperator on the ball joints, first one then the other. They probably won't pop off the first time you hit them so work on the top one to loosen it and then the lower one. Keep doing this and it will pop off. Do you have ftn96's write-up? If not I'll hunt it down for you.
  3. rampage
    Mar 20, 2001
    2,260
    72
    <a target="_blank" href=http://nashvillek5.freeservers.com/balljoints.htm>ftn96's ball joint write-up</a>
  4. 85 Shortbox
    Jan 24, 2002
    138
    Grandville, Mi
    Thanks, it's a pretty good article that is deffinetly going to help.
