Anybody ever bend a 14bff?
Discussion in 'The Garage' started by goldwing2000, Nov 17, 2006.
  1. goldwing2000
    goldwing2000 Guest
    So I put this axle under the Blaze, thinking it would be indestructable but now I'm having some doubts.
    I haven't even taken it wheeling yet and I got it from a guy who had it on a Heep with 48s, so I know he didn't have a lot of weight on top of it but I'd swear that I'm getting way too much negative camber.
    It's not leaking from the tubes and nothing looks to be obviously out of place but I dunno. The rear wheels are definitely //=O=\\
    I'll try to get a picture tomorrow. :confused:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Loose wheel bearings? Anything can be bent, especially under 48s regardless of how light you think it is (a jeep tub doesnt mean crap as far as weight is concerned when the vehicle is on one tons and big tires).
  3. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    I just swapped out a bent one on my truck. from someone overloading the truck it was in. ran it for a year though. if you take the axle bolts out, they shouldn't separate from the hub by themselves! mine would have a 1/16 gap on the top and tight on the bottom. made it drive squirly.
  4. goldwing2000
    goldwing2000 Guest
    Dang. Looks like I may be looking for another 4.10 14b.
    So much for all the work on my custom spring perches and shock mounts. :mad:
  5. goldwing2000
    goldwing2000 Guest
    So let me throw this out there:
    Is it worth the hassle to try to straighten an axle?
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Not when they are a dime a dozen.
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah i would imagine it would take quite a machine to do it right, and with 4.10 being a fairly common ratio i wouldn't waste my time.
  8. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Dime a dozen my arse... down here the junk yard wants atleast $500 for one... no matter the condition. Maybe I just don't have the right connections... :(
  9. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    For $400 I will strap one to a pallet and ship it right to your doorstep. unless the shipping cost me $300 I would probably still not lose money. they are a dime a bakers dozen up here. I want to move where dana 60's are a dime a dozen.:rolleyes:
  10. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    get mountainexplorer to adopt you :doah:
  11. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    I THOUGHT I bent one!..
    I accidently backed the 1700 Trojan Forkloader we had at the junkyard right over a 14 bolt FF I cut out of a '71 P-30 step van with an 11,000lb axle rating one day--I was moving the remains of the P30's carcass and didn't realize I'd backed over the axle until I turned the loader around to pick it up,and noticed it was buried in 6" of mud that was half frozen!:doah: ..the guy buying it looked like he was about to cry!..
    I picked it up,and brought it inside the building..we put tires and rims we had in a pile on it--they appeared to be standing up straight,so the guy bought the axle--I knocked 20 bucks off the price, in case it was damaged and he had to bring it back and swap it for another (was the only one we had though!)..but he used it in his 78 K20,and said he didn't hear any noises,or any unusual tire wear after several months,so he guessed it wasnt bent a bit!..that loader topped the scales at 21,950 lbs too!..:eek1: ..
    I've cut quite a few FF axles up for scrap,and the axle tubes are 3/8"to 1/2" thick,not too easy to "tweak"...but if you DO succeed in bending one,I doubt you'd be able to "bend it back"..even if you could,I bet it would bend easily again once its been bent once..I'd get another axle if it were me,and use the bent one for parts..:crazy:
  12. goldwing2000
    goldwing2000 Guest
    Yeah... that's what it's looking like. :mad:
    Back to the classifieds...
  13. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    I swear mine is bent but I have no problems or uneven tire wear. so I have run it like this for about 3 years. around here i can pick one up for $50-$100 but I want a van width, and those are a little hard to find.
  14. goldwing2000
    goldwing2000 Guest
    That's good to know. I'll probably wait and see what the tire wear does before I drop any more coin.
    And yeah... van-width would be sweet. I ain't afraid of a little cutting and welding. :D
  15. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Bought my van width for 45$ with POR-15 already on it!:D
  16. goldwing2000
    goldwing2000 Guest
    Damn you... :mad:
    Why are all the good parts out west?!?! I was looking at Pirate yesterday and there were like a gazillion 14bff for sale... in California. :angry1:
  17. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I have been running mine for 8 or 9 years now. It has been bent for alot of those years. You can see it when I pull onto the asphalt from the dirt. The tread on the tires touches the ground all the way to the inside of the tires but about 1 1/2 inches of the outside does not. The tubes leak where they are pressed into the center section and at the spot welds. I'm going to keep running it till it breaks.
  18. goldwing2000
    goldwing2000 Guest
    Sweet. Run it till the wheels fall off! :waytogo:
