Anybody ever lowered an np205 t-case...?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JimmyUp, Apr 2, 2003.
  1. JimmyUp
    JimmyUp Registered Member
    Mar 28, 2002
    55
    Seattle--Washington
    Hello,
    Has anybody lowered their np205 t-case that has the factory skid plate and dual crossmember brackets (i.e. connects on both the top and bottom the of the frame on both sides)?
    After installing my 6-inch lift (nightmare project--excessive bumpsteer) I have minimal driveline vibration in the back. I should also mention I am running a TH350/np205 combination. I did this on my old CJ-7 to relieve driveline angle/vibration /forums/images/graemlins/usaflag.gif and it solved the problem.
    Thanks for your feedback,
    Scott
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Scott,
    I suppose that's one way to deal with it....but the 1st Gen's xfer cases are already pretty low compared to the later model K5's....if you 'wheel, going even lower is not the answer.
    How about doing a little "shimming" on the rear axle instead? You should be able to achieve the same effect... Or go with a CV-driveshaft, but that's $$$
  3. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    Yes you can lower the transfer case i lowered mine 1 1/2 inches when i 1st did my lift but make sure you move the brace that connects to the transfer case to the frame. I found out the hard way last year at blazer fest i cracked my tranny. Now that i have a high pinion 60 in the rear im going to put the transfer case back in the stock location. <font color="red">1 FN HI K5 </font>
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    How exactly did you move the t case mount??
