Anybody ever played w/traction/ladder bars?
Discussion in 'The Garage' started by pismorat, Mar 2, 2004.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I want to fab up some traction bars for my /forums/images/graemlins/truck.gif, has anyone ever made them or had experience with them? Just want some feedback whether it's worth it or not. /forums/images/graemlins/peace.gif
  2. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Whether it would be worth it or not would more likely depend on your application, if your running a shackle flip and soft springs, like me, then, like me, you will be making a set of anitwrap bars for your rig. If you get alot of wheel hop then you might want to put them on there too. I plan on fabbing up some bars similar to the ones that azkickin sells (bit pricey) they look like they would work well, they dont limit flex but keep the diff from twisting.
    http://www.azkickin.com/antiwrap.htm. but you need a 14 ff to bolt it to the pinion nose. Ill let you know as soon as I get them together.
  3. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I currently have the 4" springs in the rear. I was thinking about adding the 2.5" shackle flip kit and then 6" springs in the front. Do you think I will have more axle wrap if I did that? I don't really notice much right now.
  4. sidslc
    sidslc Registered Member
    May 27, 2002
    96
    slc ut
    Yes it is a great thing to do nomatter what type of wheeling you do even if it is on the street only. However you need to look around and pay attenion to what works and what dosent. I am on my second design as we speak and I think I have it figured out for flex. Look at pics.
  5. pismorat
    Oct 29, 2002
    540
    California
    That's a good idea, but is it better to use one or two? I was thinking of running two tubes down from each frame rail to the axle with hiem joints, but the articulation is what messes me up. /forums/images/graemlins/truck.gif
  6. pismorat
    Oct 29, 2002
    540
    California
    If I were to use hiem joints, what size would be good: 7/16", 1/2"...? And if I ran them outboard the frame, how long would they have to be to not bind when flexing? Thanks. /forums/images/graemlins/truck.gif
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would use at least 3/4" shank rod ends. For the front I wouldn't even use a rod end. I would use a spherical bearing (also called a uni-ball) and weld on cup. www,stockcarproducts.com is a good place to get them for cheep.
    ROD ENDS ARN'T MADE TO TAKE BENDING LOADS!!!
