Anybody Gernade the 241?
Discussion in 'The Garage' started by Sandman, Jul 19, 2004.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm still trying to decide if I want a doubler or just stick in the 241. I have the 203 and the 205 for the doubler and I also have a 241. If I do the 241 I will put on the SYE kit.
    So how tough is the 241?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thay are marginally stronger than a 208 , of which all I wore out/broke was a shift fork /forums/images/graemlins/k5.gif
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I blew several 208's before I went to the 205. I thought the 241 was decently stronger then the 208. Hell, I have a 241 in my 1 ton dually. And I haul some pretty heavy stuff with it. I'm just worried about the shock load.
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i've been through 3 with a stock 350/700r4 /forums/images/graemlins/eek.gif
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If it is protected by rocks , I wouldn't worry about it . I know people who run them on real trails and don't break them . If its a street truck , camping truck , light trail rig , it should be fine unless you drive hard /forums/images/graemlins/k5.gif
  6. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    What is a SYE kit?
    Eric M.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I doubt you would break a 241. They are fairly stronger than a 208.
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Not fairly stronger...maybe marginally stronger. Better oiling system was about the only substantial change.
    Chain size, shaft size, are all nearly identical. The 241 planetary might be stronger, but the lo/high range collar is a definite weak point.
    My biggest worry with one is the cast aluminum case though.
    Rene
  9. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    What is a SYE kit?
    Eric M.
    Slip yoke eliminator...
    So far my 241 is holding up well... hell, I never had any problems with the 208 in a previous truck /forums/images/graemlins/dunno.gif....
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I'm gona run a 241 drivers drop. I think it should hold up.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have an idea of what you are planning if its going in a pass drop truck ........do it before you post about it though /forums/images/graemlins/whistling.gif
  12. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    I wonder were ya got that idea from Paul /forums/images/graemlins/whistling.gif Yes a 241 has weak points, so does everything, so yes you can break it. But then again everything is breakable just depends on how you drive and how much skinny pedal you use.
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Is it for your Blazer? If so I would run the doubler. It is stronger and will last longer. I would do the doubler since you already have the cases for it. I run a 208 and it works fine for my moderate trail needs but for something that is going to see alot of abuse I would step up since you already have the parts.
    If you didn't have the 203 and 205 I would say run the 241 till you break it then swap but you have them so swap.
    The 241 can work fine for up to moderate use in my opinion but if you are running it in a heavy truck on some heavy trails then go with the doubler. One less thing to worry about.
    If you do decide the 241 is staying then make sure you have a bad ass skidplate for it. That aluminum is REALLY thin.
    Harley
  14. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I think they are pretty tough, last year at uwharrie i ripped my t case mount on half horonzally (sp?) when my rear diff got hung up on a rock, after a few tries to go around i just started smoking the tires, anyway it was in two pieces but we didnt know it so we ran trails for the rest of the day, once back at camp i saw a ATF drip, got to looking and my driveshaft had shifted about 4 inches over but never had a problem the case /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    are you serious? were they from the junkyard? what happened to them? are you playing prerunner w/o a skidplate?
  16. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I blew 2 last year with 38's. Replacement cost was $750 with my core. So when the second one went I decided to spend the money on the Doubler kit. I don't think they're that strong.
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Lost me on this one. No secret here. Drivers drop truck, Ford HP 60.
    Sandman, How's that center of gravity coming. What is the weight these days.
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Nevermind then , its a secret coming out of the desert later this year , outside the box for sure . I shouldn't of said anything /forums/images/graemlins/waytogo.gif
  19. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've decided to go with the Doubler and just sell the 241. I am hard on my stuff and I think I might break the 241. I will gain a 100+ pounds or so but Oh well.
    I've got it down to 5,120 pounds with trail tools and a full tank of gas (not me in it). I plan on going to a fuel cell and an AL radiator. Also a Lexan Windsheild when I can get to it. Hopefull that will help offset the doubler. /forums/images/graemlins/grin.gif
  20. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I am pretty sure he lost one on the freeway. /forums/images/graemlins/screwy.gif I think he lost his from other issues, not just from wheeling. I may be wrong but that is what I remember. /forums/images/graemlins/thinking.gif
