anybody good at electronics?
Discussion in 'The Garage' started by Jishory, Mar 28, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Swap your 30 and 87 over.
  3. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I just dubble cheaked mine...
    85 ground
    86 batt
    87 light
    30 switch
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Just like 2dogs and every motor factors and manufacturers does!
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I have actually come across a vey obscure relay that is wired something like that. But that is not the norm. I'm not sure why they were made like that. I thought at the time that I'd just bought a dodgey relay. If yours works ok like that then fine, but most common relays are as 2Dogs' diagram.
  7. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    ill take a picture of the relay maybe we can come to a concensus
  8. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    this is what it shows on the relay
  9. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    2dogs diagram is way you need to wire up your lights with your relay.
  10. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    im wiring mine up like 2dogs diagram exept im using 6 lights, switches and relays. im also using both accesorie prongs instead of just one.alittle more wire to run but thats fine. i had all the relays already so its no biggy.
  11. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    2Dogs is correct. You could switch pin 30 and 87 for this application and it will still work. You'll only have a problem switching those pins if you need to use the normally closed contact 87A.
  12. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    mine has the stock KC relay but has a pic of the connections on the side so it works for me:dunno: .
  13. 87350blaz
    87350blaz Registered Member
    Oct 23, 2005
    33
    New Mexico
    might have a problem with what is shown in the diagram though.....with 2 grounds coming off of the switch your power is going to take the path of least resistance. depending on which has a higher volt is going to determine which one will not work.
    I would just wire the light in series with the relay, but you will have a problem if the light burns out then your relay wouldn't get power.
  14. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    ill try it the way 2dogs reccomended, thanks guys :bow:
  15. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :haha: Sorry, I just had to laugh (SIJHTL?)
