Anybody had their frame straightened?
Discussion in 'The Garage' started by fordeater, Jul 12, 2006.
  1. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    I've got a frame from a 69 Chevy 3/4 ton 4x4 that is bent a little in the front. I want to get it straightened before i install the motor and cab. I can't exactly get it to the body shop to figure out how much it will cost me, so i was wondering if anybody has experience in straightening frames, or knew about how much it would cost. I even thought about straightening it myself, but i don't know how to go about doing it.
    It isn't bent bad, but i want it straight, as you can see in the pic, it is bent towards the drivers side from the engine crossmember on forward.
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I'd take a few photos to the body shop and see if they can give you a rough estimate.
  3. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    i tried that, but the prick at the body shop by my house said he couldn't give me any kind of estimate without actually seeing the frame. I explained that i had no way of getting it there because it doesn't have a motor, cab, or tranny, and that i had no way of getting it there, and he said he couldn't do anything.
  4. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I had my frame pulled on my 79 2WD blazer a few years ago and I think it cost a little over $200.
  5. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
    Can't tell much from the pics, but yeah, I ran a frame machine for a few years...
    Trust me, unless it's the simplest of pulls, you need to put it on a machine with anchor pots, etc... Once in a while you'll find one you can get done with a porta-power, but nothing compares to making proper pulls with a frame machine...
    If you wanna figure a worse case scenario kinda gig, figure maybe 8 hrs labor... Probably less.. Not sure what the body shop rate is these days, but say $60 x 8 hrs = $480.. Thats on the high side I'd guess...
    You'll eventually have to tow it to someone.... I don't know what you expected the guy to say... Not likely he's gonna come to your house, not his job...
  6. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    nah, i didn't expect him to come to my house. I was just looking for a ball park figure so i know what i'll be paying because i didn't feel like renting a trailer to tow it somewhere for an estimate and then renting a trailer again to actually get the work done. They just changed management, and i'm not impressed by the new staff, which is why i think he is a prick.
    Would they still be able to repair it pretty easily with the motor and stuff on the frame, or should i wait to put everything back on until after i get the frame straightened?
  7. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
    Might wanna make a few calls around... Check on there labor rates too....
    Easiest pull would be with the motor out, but your front sheetmetal on, minus wheelwells.... That way they can locate that side rad support location.. just leave that mount out, but bring the parts with you..
    so you'd need the cab mounted and front sheetmetal fitted up.... You can do it by measurement, but it's easier the other way..
  8. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    Yeah, the guy's probably not trying to be a prick - it's very hard to determine exactly how bad frame damage is from pictures. He's probably just trying to cover himself from giving you a bad quote. Honestly, I doubt you'll find any reputable frame shop that'll give you a "ballpark" estimate without seeing it in person.
    That said, I've had three frames straightened over the years (in varying degrees)...the worst one cost me $400, and that was with both frame rails forming a sortof trapezoidal shape :crazy:
