anybody have any basic bumper plans / receiver winches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Mar 24, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    any bumper plan somebody would like to share? I'm looking for some plans that I can modify to start making the plans for my bumpers (front & rear).
    what are the con's to a receiver style winch that can be moved front or rear?
  2. solowookie
    Mar 31, 2001
    3,880
    Wyoming
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The winch will be more powerfull and faster in the front than in the rear because of all the cable you have to run to the rear.
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well one concern is the safety of a receiver style winch; I'm wondering how safe they are, and the strength of a receiver with that much pressure on it. I plan on making the receivers into my bumpers so they are up &amp; out of the way so I get better entrance / departer angles etc.
    even if I loose a little power with a winch on the rear that really isn't a big concern.
  5. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I'm going to be building my own bumpers with triple receivers in both. A center-in-the-bottom receiver for towing &amp; dual's on the ends of the frame for winch multi-mount &amp;/or snowplow set-up.
    Sorry, no plans yet but it'll be simple 2x5 or 2x6 with possible wrap-arounds. The only drawback I can see to a multi-mount is that if you're buying one (like Warn for example); they're usually limited to 9000lbs so your winch size is limited.
    My dual receiver setup should be able to handle much bigger if I want. /forums/images/icons/smile.gif
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea, but I would be happy with a 9,000 so that really isn't a problem for me. I don't care about mounting a snow plow cuz I have access to a big tractor with a front end loader, and an old dump truck with a plow on it if I need it.
    I'm curious why you'd need 3 receiver points for extraction though? I would assume one point in the middle would be sufficient. However, I'm not putting D rings on, but on front &amp; rear I plan on just having a triangular solid piece where I can put a clevis pin through when I need to so I don't have to listen to the D rings rattle all the time.
    I will do wrap arounds, but I'm not going to just use just a piece of square tube; it will be a little more then that for looks, but not too much. I want the bumpers as high and tight as possible, and then they will wrap around, and I will cut off all sheet metal that extends below the wrap arounds.
  7. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I've got dual receivers in both my bumpers. I have no where to post pictures, but i can send you them if you like. Only problem with my setup is the winch/cradle weighs alot, but i guarentee it will fail. - Doug
  8. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    if you send me pictures that would be great, and if you don't mind I will post the pictures for you; jeff@vtengineering.com.
  9. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I just built a double tube bumper but no reciever. If youre interested, Ill get a pic and send it to ya. I also have AutoCad so i could send ya some drawings.
  10. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    oh yea, that would be great!
  11. outlaw612
    Feb 11, 2001
    2,342
    Ill send them to ya when i get home tonight after work.
  12. outlaw612
    Feb 11, 2001
    2,342
    I sent the AutoCad drawing, Im working on the pics now.
  13. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Outlaw, could you CC me on those plans? i *just* priced a set for the K5 and the guys said the START @ $1300.
    So i think i will build my own/forums/images/icons/laugh.gif
  14. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    can you convert these from autocad to an image file like a .jpg or something?
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    JC Whitney sells a reciever hitch for the rear rated at 15,000 lbs. If that's not enough, no hitch will work.
  16. outlaw612
    Feb 11, 2001
    2,342
    Im not able to get to my computer at home cause Im out of town till Sunday. Ill make the drawing into a jpeg and send it to ya when I get home if yould like.
  17. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks /forums/images/icons/smile.gif
  18. outlaw612
    Feb 11, 2001
    2,342
    I will be back home on Sunday afternoon, I need to put the drawings into a jpeg and then i will send them to you as I need to resend to Jeff also.
  19. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hey Solowookie....If you are interested, I can draw up some plans for the bumper I'm fabbin'. Don't know if its the style you are lookin for, but I would be glad to help ya. If ya want. /forums/images/icons/smile.gif
  20. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    give me a basic description would ya?
