anybody have any trailer plans
Discussion in 'Tow & Trailer' started by bad_bo_ti, Dec 2, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    seeing if anyone has any trailer plans to share with us, i am thinking of maybe making my own trailer. something else that might not hurt is maybe a list of helpful trailer websites for parts and accessories! if you have any plans and would like to share them either post here with a link or send them to me at bad_bo_ti@yahoo.com thanks, chris
  2. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    hay if anyone sends you plans can you send them to me K10chvy77@aol.com thanks
    Andrew
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Check the link post at the top. There's some good info there.
    BIGJ
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I have some trailer plans I made but need to update them a little. I originally used angle iron crossmembers and need to change it out to channel iron instead to make things a little stronger. This was a 6 x 10 utility trailer though, not a car hauler.
  5. bad_bo_ti
    1,027
    OhiO
    yea that is what i am looking for more of a car hauler, i would like to build a regular bumper(hitch) pull trailer first maybe to handle like 10,000 lbs or a little less. i am sure i can make my own drawing though for this but my main concern is what type (c-channel box) metal and thickness to use, i plan on it being a tandom axle with both axles having breaks not sure if i want a deck over or a low boy type. thanks again for all the help
  6. kennyw
    Jun 9, 2002
    13,224
    94
    C channel or I beams will be the cheapest way to get the strength you need. Square and rectangular tubing will be 3-6X the cost. For 10,000# Cap trailer 8-10" channel should be good with 2 main frame rails. 3-4" channel crossmembers with 2" decking to top it off.
    You could borrow this flatbed plan I made and modify it to make a trailer:
    Flatbed Plans
  7. bad_bo_ti
    1,027
    OhiO
    what about weight though, will the i-beam or c-channle trailer weigh more than a box tube? i guess i should add that i will be pulling this witha 1/2 ton 4x4 chevy untill i get something else. thanks chris
  8. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Try this: Trailer Plans
    I've not ordered anything from this place - just been browsing. Their plan for Model 1218 looks appealing.
    Ronnie
