Anybody know about outboards?
Discussion in 'The Lounge' started by sickquad, Jun 29, 2005.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I just boat a small fishing boat with a 25hp 2 stroke mercury. 1984 version.
    I'm thinking that there should be some sort of gear fluid in the gears which turn the prop. Am I right? Anybody know what type of fluid goes in there? I can't even figure out how to get some fluid in there.
    Any help is appreciated.
    -Chris
  2. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    lower unit oil... available from any marine store...
    should have 2 plugs in the side, one high one low... to fill you pump it in the bottom till it comes out the top plug... sometimes the lower plug is behind the prop..
    should be checked annually to make sure it hasn't milkshaked..
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i just put some in mine it is a marine grade 90wt
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Get the pump to fill it, you'll be glad ya did!
  5. sickquad
    Jul 23, 2003
    785
    Ma
    Pump it in the bottom till it comes out the top? That sounds weird. Maybe I have to look into some sort of pumping mechanism.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    You can use the "tube" of oil, but the pump they sell just for that works superbly!
  7. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    yeah, it does kinda go against what you would normally think.. ;)
