Anybody know anything about sprinkler systems??
Discussion in 'The Lounge' started by shane74, Sep 27, 2002.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I am trying to get the one working in our new place and it just won't cooperate! Here's the deal. The system was installed several years ago (woohoo for us!). I found out the controller box was bad so I replaced it with a spare one from our previous home (I know it's good). A couple of the heads were busted so I repaired the pipe and replaced the heads. The valves will work ONLY if you turn them on and off maually. The controller box has no effect on them. I know the valves are getting power (I used my multi-meter), so I think I need to replace all of them (there are 4). If that doesn't work, I am at a loss as to what else could be the problem /forums/images/icons/confused.gif Has anybody here had to deal with this? I would like to get them working so I can go back to being lazy except for when I am working on my blazer!
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    If your getting power to the valves and you have a good ground, the valve has to be bad.... I had to replace mine at the old house.
  3. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    The valves are home despair specials. I'll see what I can pick up to replace them with.
