ANYBODY KNOW HOW TO READ AXLE CASTING #'S ?
Discussion in 'The Garage' started by PERRO, Jul 11, 2003.
  1. PERRO
    PERRO Newbie
    May 20, 2003
    ANYBODY KNOW HOW TO READ AXLE CASTING #\'S ?
    /forums/images/graemlins/1zhelp.gif I HAVE A GM 8 LUG FRONT AXLE WITH 10 BOLTS. I FOUND SOME NUMBERS ON IT AND WAS WONDERING IF ANY ONE KNOWS HOW TO READ THEM? FIRST: 44-5CF ON THE HOUSING. SECOND: THEIR IS A 2 ON TOP OF A SERIES OF NUMBERS C36585 ON. THIRD: TAG ON BOLT TOP# 48-11 BOTTOM# 4-89. IT ALSO HAS SOME FINS ON THE SIDE OF THE HOUSING.
    ANY HELP WOULD BE GREATLY APRECIATED. /forums/images/graemlins/ears.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: ANYBODY KNOW HOW TO READ AXLE CASTING #\'S ?
    <font color="green"> The tag on the bolt has the tooth count for the R&amp;P and the build date, the C36585 is the RPO#, I beleive, and the 44-5F is likely the casting number for the center section. </font>
  3. dyeager535
    26,980
    Any chance you can get a pic of the tag? I've *never* seen a GM axle with any tag other than the limited slip/posi tags.
    Just curious what it looks like.
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    yeah, how can i figure out what year my 14FF is off of?
    Perro: there is a button to the left of the "A" key, press it one more time please /forums/images/graemlins/grin.gif
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Really? My original '78 12b and D44 had the tags, and so did the D60 and 14b that came off an 87... </font>
  6. dyeager535
    26,980
    I've had maybe 8 10 bolts in my career, (none from late 80's) and none of them have had tags. Dealt with plenty of 8.5's and 7.5's (car axles, 10 bolts, for those not in the know) from the early-mid 80's as well, and none of those had any tags except the limited slip diff if so equipped.
  7. dyeager535
    26,980
    Don't know how axle casting dates work. (if they even exist) Engine date castings, typically they are made early in the model year, or late the year before. (so an '86 truck might have an engine casting date of late 1985) But axles could have been made in huge lots for say 2 years at a time or something. If they didn't do it (intentionally) for engine blocks, doubt they would have for the axles either though.
    Rear axles have a 2 or 3 digit code stamped into the passenger side axle tube. (either on the "top" as installed in the vehicle, or facing forward as installed) No clue if that applies to front axles as well. Once you get that number, you still have to figure out how to decode it, and that too is difficult. With cars, those codes changed almost every year, and were not indicative of year.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Kinda a crappy pic, but is one i just took off my 75 D44 with 3.08 gears.
    Tag reads: 45 14
    3 07
  9. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    44 = Dana 44
    5 = Series # (in the late 60's they were on 2)
    C = Chevy (just a guess)
    F = Front
    No clue
    Are you sure that isnt a 45-11? That should be the ring gear to pinion ratio (45-11 is 4.09 but 48-11 is 4.36).
