Anybody know the specs on the stock roller cam in Vortec motors?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Aug 5, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    For a 98 motor, 350, does anybody have the specs?
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Well it's probably under 200 degrees @ .050" and probably about .400 lift. It will most certainly be a split pattern cam (most GM cams are) with a bit more duration and lift on the exhaust side.
    Part of the reason these cams are so tame is because they are made from cast iron as opposed to steel like other roller cams. Cast iron can't hold up to the fast ramp rates common to roller camshafts.
    Are you trying to replace it with something identical or do you want to just "go up a step"?
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Somewhere I have the cam that came out of my Vortec motor. I just havent got a CLUE where it is! Otherwise I would try to measure it for you. /forums/images/icons/tongue.gif
    Ask Twiztid, he works at a GM dealer and may be able to get the specs form a book there.
  4. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Actually Chris, they are the prettiest shiney billet steel. /forums/images/icons/grin.gif
  5. dyeager535
    26,979
    In any case, the "tamer" cams make more low end torque, and GM's newer motors tend to be REAL torquey.
    (and are more likely to get better mileage, so less emissions concerns)
