anybody know what axles on 83 F350 crew?
Discussion in 'The Garage' started by jimmy88, Sep 13, 2002.
  1. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    See one for sale, cheap. Are the spring perches the same width? If they are Danas, is it worth looking at or would it just be a headache?
  2. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    i wanna say dana 70 rear and dana 60 front. not for sure tho. it would be a headache to use cuss the differential on fords are on passenger side while all others are on the drivers side. ya can use em but it takes alot of work. better just lookin for gm or dodge dana 60s. hope this helps and if neone can correct me if i'm wrong go for it. just tryin to help /forums/images/icons/smile.gif later.
    jacob
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    If it has a solid front axle and not TTB it will be a reverse cut (high pinion) dana 60. But my guess will be the TTB for 1983.
    If you luck out and it is a dana 60 front take the money you save and buy a 4L80E and chevy t-case for a IFS truck and you have a pass side driveline. /forums/images/icons/grin.gif
    Rear is most likely to be a Dana 70.
  4. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I believe the F250 used solid axle w/ TTB and the F350 use solid and leaf spring. Should be a D60 front and Ford 10.5 rear if SRW.
  5. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    I believe f-350's were Dana 50's (drive's drop) until '86 when they went back to D60's. The rear should be a Sterling 10.25 if SRW and D70 if DRW I think.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    f350 were solid axel d60's or d50's. the rears were sterling 10.25. f350 were leaf spring and f250 were leaf spring with an independent d44. either way, the pinion is on the drivers side. conventional chev is pass side. driveshaft would suck!!
  7. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Mattman hit it on the nose on the front end. From 80 thru 86 Ford went cheesey and put the TTB D50 in both the F250 and the F350. I think the rear will be a SEMI-floater D60 on a SRW and a D70 FF in a DRW. I may be wrong on the rear end but I think the Sterling rear axle wasn't introduced until the mid to late 80's.
  8. Brian85gmc
    Brian85gmc Registered Member
    Sep 4, 2002
    37
    Canton, MI USA
    front= driver side dana 60(not gonna work with your passenger T case)
    rear= sterling 10.25 FF
