Anybody know what cuts cable really well?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88MudBeast, Apr 10, 2001.
  1. 88MudBeast
    88MudBeast Registered Member
    Nov 8, 2000
    67
    Dallas, TX
    What cuts cable well, besides the obvious hack saw, which is slow and monotonous.
    Big Jake
  2. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    Bolt cutters torch works the best becouse it kinda melts the end together helps hold the cable end together ive found
    Bandit
    (Your right i dont understand the jeep thing)
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Plasma cutter...or a one of those cutting wheels($4) you slap on the end of your drill.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  4. 90STYLE
    90STYLE Registered Member
    Mar 23, 2001
    31
    AZ
    I cut alot of stainless braided hose...prob. the tuffest thing to cut clean...what i do is wrap tape around the piece and cut it with a cut-off wheel. I would imagine that it would work on cable too.
  5. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    .44 mag...lol better be a good aim!
    Blow torch would work just fine.
    I use my dremel alot to...works good
    "Fool me once shame on you...fool me twice shame on me"
    "A closed mouth gathers no foot."
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, as others have said, I've used everything from a set of leveraged shears (similar to bolt cutters) to cut-off wheels, oxy/ac torch, tape/hacksaw,... Whatever is handy. Tape/hacksaw is probably the hardest and most trouble. Shears and cut-off make the neatest cut. Torch is fastest if you don't have a shear but it has never done much for me as far as melting the ends together. The oxy part of oxy/ac along with the blowing pressure sort of inhibits that...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  7. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I second the plasma cutter... but not every one has one of those....
    [​IMG]See me at <A target="_blank" HREF=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</A>
  8. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Hey all
    The last shop I was at had a plasma cutter.
    It was a smaller one but it would slice 1" steel like butter.
    It was realy handy trimming stainless steel fenders too.
    As for cable the torch works for me. But if I want it to look nice , I'll put some heat shrink on and slice it off with a cutt-off wheel.
    Works good for nylon rope too.
    See ya
    my truck's not dirty, it's earth tone paint
  9. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    If none of those things work you could run over the cable with a plow. I work at an airport and we have these cables strung along the ground. They are used to tie down airplanes for the night. Anyways, it snowed one night and I drove right through two of them while plowing the ramp. It cost something like $350 to get them replaced ... oops! [​IMG]
    '87 Beast
    Colorado, USA
  10. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    What kind of cable. I would just use the old grinder, why bother firing up the torch.
