Anybody know what pressure the brake system runs at?
Discussion in 'The Garage' started by dremu, May 3, 2006.
  1. dremu
    Feb 27, 2000
    15,969
    462
    East of San Francisco
    I'm trying to chase down a potential leak in my brake system ... thinking I could pressurize the hardlines, do a leakdown test. Anybody know 'bout what pressure the brake system runs at ... I swear I remember 1200psi once, but then the pressure bleeders tell you to run below 20psi so you don't blow anything up... any ideas?
    Also, I presume the gauges we use for air would NOT work very happily for brake fluid, so I should leak test with air?
    -- A
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    have seen brake pedal pressure testers with 1500 psi gauges on em.
    i think they tell you that on the pressure bleeders so that you dont overpressure the master cylinder resivior which is usually at atmospheric pressure.
    can you just lock the brake pedal in place with a block of wood against the seat and check for leaks? or have you already tried that?
  3. dremu
    Feb 27, 2000
    15,969
    462
    Well, carp, hadna thought of that :doah:
    Of course, the pedal goes all the way to the floor, which is what I'm trying to fix ... but I'll start with that. Thanks!
    -- A
  4. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    You may also try blocking each brake hose one at a time and see if your pedal height changes.
