Anybody run without a kickdown on a TH350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Calclips, Sep 26, 2002.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    What did you guys do to keep the tranny fluid from puking out of the hole where the cable attaches to the case?
  2. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    just cut the cable off,and bolt it back into the tranny so it dont puke out.......do it on my race cars.........works fine.....dont forget to pinch the end of the cable where ya cut it off...
  3. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    What's the purpose of the kick down cable and why cut it?
  4. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    For the tranny to shift properly in normal use, the cable must be installed and adjusted correctly. The cable attaches to the detent valve in the trans and directs regulated modulator pressure to the 1-2 and 2-3 shift valves. It provides WOT downshifts and part throttle 3-2 downshifts. There is no reason to run without it on a street driven vehicle.
  5. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    As Barraza said no sence in running without it unless you don't feel like running to the store to spend 10-20 dollars on a new one. On the other hand you don't need it to shift up you just need it to shift down when your on the skinny pedal. You can always manually shift it with no problems, but the decision is obviously yours. Only time i've heard of that you really need it is with a 700r4. The kickdown kinda acts like a life line for your tranny... /forums/images/icons/grin.gif
  6. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    Mines not hooked up. Ineed to fab a bracket for it since the old one won't work with the vortec heads. Its been like that for about 2 yrs now no problems, but I never drive it on the street.
  7. StiffRide81
    StiffRide81 Registered Member
    Aug 24, 2002
    53
    Tinley Park, IL
    If you dont have a manual\automatic valve body.. and you take it off... you are eventually going to kill that automatic valve body. Just be ready to replace it. I did the same on my monte carlo. No kickdown, with ratchet shifter. Blew it. installed manual/automatic.... never had a problem since... But I must say.. without one.. eventually, it sucks @ss.
  8. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Ya, especially when it shifts into 2nd and you want to pass someone. Impossible without that kickdown and these 39.5's.
  9. dyeager535
    26,980
    Your '85 has a TV cable (if stock 200-4R) the TH350 uses a detent (kickdown) cable, totally different animals.
