Anybody running a locker in a 2wd?
Discussion in 'The Garage' started by OffRoad, Jan 5, 2007.
  1. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    i've got a 90 c10 on 29s, that i'd love to put a lockright in. anybody running a similar setup?
    i'm worried it'll fishtail real bad in the winter on the road. i don't have 4wd to pull out of it, and i can't really run 4wd on the street anyway.
    i don't see a 4wd in my future, so i'm trying to make my 2wd perform a little better. i don't wheel this. just for DD and out on coutry roads/dirt roads stuff like that.
    i'm not worried about summer, it's the winter part i'm worried about.
  2. Masontw01
    Masontw01 Registered Member
    Feb 1, 2006
    13
    South Carolina
    i don't share your problem, but wouldn't a good solution be to get an airlocker so that if you need it you can have it, but if in the snow you can't get traction you can turn the locker off? sounds like a winner to me!
  3. OffRoad
    Dec 8, 2002
    852
    air lockers (and any other selectable locker) are lots of $$. can't afford it. i'm pretty sure lockers are cheaper than limited slips, so i'm going this route. plus i don't want a limited slip, i want a full lock.
    if i had lots of money i'd do what you're suggesting. :)
  4. Masontw01
    Feb 1, 2006
    13
    South Carolina
    i see. i was under the impression that an air locker wouldn't be a whole heck of a lot of extra $ compared to a normal locker. guess i was wrong! good luck though.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The 10 bolt ARB I bought used came out of the rear of a C10 in Minnesota.
    I've read more than a couple tales of woe in dealing with lockers on ice & snow, but I'm not qualified to make any direct comments since I live on the Left Coast.
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    my old truck was good in snow till detroit install. more than 2-3 " on ground it was time for 4x4 to go stright line or the back end fished out to darn easy.
    with that i run a 2x4 1ton. i have 14ff rear. i love my stock gov-loc in the back end. open till i need it and drives great. havent been stuck yet with her.
    but i would only run a 14ff gov-loc never any smaller axle ones thay blow to darn easy.
  7. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    I have a detriot in the rear 14 bolt and I do not like to drive it in the rain. If it's a DD, I would recommend a selectable locker or a limited slip for the bad weather. Heck, even in good, dry weather I have to remember the locker is back there while going around corners.
