Anybody running a spacer under the TBI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chili 87 K5, Jan 12, 2001.
  1. Chili 87 K5
    Chili 87 K5 Registered Member
    May 8, 2000
    29
    CO
    Please: If you know what the ballpark timing should be for a new 1" TBI spacer, give me a hint... I just need to know where to start looking.
    Is it closer to 12 degrees BTDC? 20 degrees? Is there a good place to start trying?
    Thanks!
    Chili
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'd be totally amazed if adding maybe 4 cubic inches to the volume of the intake manifold would require a timing change. The difference in total intake volume is probably less than 1%.
  3. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    I have an Airaid on mine and I didn't have to change the timing at all. I did have to adjust the linkage on the tranny to fix the shift points.
    GOT ROCKS?
  4. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Can you notice any difference with these things?
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have one on mine, and it seems to help out a little.
    90K5
  6. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I'm running a injector spacer and the edolbrock intake. Plus a Turbo city cone on the air cleaner. I cant help on the timing though as I'm running a 400 block that 30 over with the stock 93 head and stuff
    I understand the jeep thing I drive a BLAZER!!
    Ken
  7. blazer72
    Apr 13, 2000
    939
    KCMO
    I'm running a injector spacer and the edolbrock intake. Plus a Turbo city cone on the air cleaner. I cant help on the timing though as I'm running a 400 block that 30 over with the stock 93 heads and stuff
    Ken
