Anybody running one of these?
Discussion in 'The Garage' started by makovai, Oct 18, 2006.
  1. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I'm ordering this exact unit except i want the vibration dampner on the top knuckle which is another $25. I'm gonna get my measurement tonight and order it tommorw. I would really like some feedback b4 i place the order. They don't give these away ;)
    Borgeson
    It will be a killer combo with my new cross steer.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Do a search on the jeep shafts. That's what I have (and will be installing soon). Not quite as nice, but the same idea for $20.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Jim, call me about this
  4. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    X2 I got an XJ shaft at the pick n pull for $12 last week and I got one during their 1/2 off sale, so I got two for $18. Read the tech article on the XJ steering shaft install. http://coloradok5.com/forums/showthread.php?t=169874
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I got a borgeson shaft. Super nice. Top notch quality. Just watch how you order it,if you decide to go with it.
    See this thread.
  6. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I was under the understanding that the Jeeps shafts didn't work with the 67-72 setup but I could be wrong.
    I recently added a Borgeson telescopic shaft (1" DD x 3/4" DD) to my 69 K20. I had previously added a Borgeson U-joint at the steering column.
    Here is a pic of the u-joint which is 3/4" x 30 spline and 1" DD to fit the power steering box I'm using which is from about a 1978 Chevy 4x4.
    and a pic of it at the steering column - the steering column was not secured to the firewall when I took the picture so ignore the block of wood that has the column wedged in place. That U-joint is 3/4" x 36 spline and 3/4" DD.
    The telescopic shaft ended up being about 11 1/2" long.
  7. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Oops. I forgot about that. Well my brother has the borgeson shaft in his M-37. Its an AGR box and IDIDIT polished steering column
  8. makovai
    Jun 6, 2006
    854
    oregon city
    But i only have half a first gen because the cross steer required a steering box from a '73 and newer 2WD. So if the jeep end fits the steering wheel side i would be good to go. I'm gonna hold off until monday and go vist the wrecking yard this weekend.
  9. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    that rig must have one helluva body lift. :eek1:
  10. makovai
    Jun 6, 2006
    854
    oregon city
    thats what i thought at first......holy moly he must have a 12" body lift ;) then it dawned on me, it is missing the inner fender skirts
  11. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I am running a flaming river setup. looks just like the picture in your first post. I peiced it together. My friend has a bunch of the shafts. I had to buy the joints. $75 a peice. it was worth it. no more slack from the rag joint. I have a stock column and 2wd box in an 83'. hope that helps.
  12. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Nope No body lift. Only 4" suspension lift and 46"s:D
  13. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I just caught a little wood. That is beautiful. Post up some more pics, just for kicks... Or tell me where you have more of them posted.
  14. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Here's a link for some more pics. http://www.cardomain.com/ride/2377952 He's been working on it for the last seven years, but this year was a little slow cause he got a new house. Some quick specs,51 Dodge M-37 on early 80's suburban frame sortened and bobbed. 1-tons, big-block 650 hp,th400, NP205
  15. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so i missed in teh original post that it wasn't a 69-91 chev. ;)
  16. makovai
    Jun 6, 2006
    854
    oregon city
    That thing is an animal.
  17. makovai
    Jun 6, 2006
    854
    oregon city
    The flaming river stuff is nice. I got a quote from them as well, but they dont offer a vibration dampner.
  18. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Damn, Damn, Damn :bow: :bow: :bow: !!!
    That beautiful beast looks as serious a 4X4 as you can get yet so clean and well done it deserves to be in yor living room next to the grande piano!
    TECH QUESTION:
    The vehicles' traction bar; Does it matter if the 'V' in the bar strattles the axle tube (like he has it set up) or can it be above the tube with the bottom-part of the 'V' mounted on the tubes' centerline?
  19. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    A couple of questions regarding your rig pic:
    1) What's the measurement hub-to-hub on your front axle?
    2) What's the rim width and backspace measurements as well?
    That's an excellent reference pic BTW :D !
  20. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    what exactly is the dampening unit it comes with? maybe I have a borgeson shaft, and flaming river joints. If it's a big coil spring wrapped around the shaft then it's not worth it. think about it, any movement your steering shaft is going to experience would be from frame to body flex. nothing is going to stop that or lessen the way that feels through the steering wheel.
