Anybody running Rock Rod drag link for crossover.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, Sep 18, 2001.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    .....especially the bent rods, is your steering wheel centered? Or is it 'off' a little bit?
    Just wanting to check around and see what everybody else's wheels were like after installing the bent rod.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I know Boss and Shawn have the Rockstomper rods and Steve has the ORD set-up so it would be nice to here from all of them to see what the difference is.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    My wheel is off just a tad. I think it's b/c I put in the Grant wheel though. I can clock it just right, but never got around to it. I put the Grant wheel on before the lift and all, and I don't remember if it was off or not, I think it was though....sorry, not much help here.
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    The way I understood it from the review was that the drag link is a bent one from ORD and the centerlink or whatever you want to call it across the front is a rockrod like in this pic http://www.offroad.com/chevy for his setup.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Mine steering wheel is just about straight when I first got mine back on the road. ANY crossover, it will effect that. Fine adjustment of the drag link will always be needed.
    Shawn
    87 K5
    few mods [​IMG]
    <a target="_blank" href=http://www.off-road.com/chevy>www.off-road.com/chevy</a>
  6. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I am running the Rock Stomper dropped drag link with a Superlift dropped pitman arm(SUP-1104) and 6" lift. With that combo my steering wheel is straight, the truck tracks straight and has never handled better.
    I may be slow, but I sure am fat!
  7. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    No probs here. I have the drop drag and rock rod from rockstomper. Straight as can be.
  8. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    I think alot of it depends on the steering arm. I made my steering arm and the Steering wheel is just a tad off. If the Draglink was straight you wouldnt have a problem. With the Bent Draglink you can only move 1 turn, where the straight draglink you can move as little or as much as you need.
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    EXACTLY!!! [​IMG]
    Thats why I am asking around to check on others wheel position.
    If you knew me, I'm picky and want my wheel to be perfectly centered.
    I'm having thoughts whether to go with the straight or bent rod.
    Anybody running a straight rod? Will they clear the crossmember or not? I'm going to run 6" springs and 1" ORD zero-rates for 7" total suspension lift.
    I would imagine the 7" would allow use for the straight Rock Rod. Any others know about this or not?
  10. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    You can only turn the bent drag link 1 turn - after installation. I would think that if properly pre-adjusted, it would be possible to have the wheel straight.
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  11. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I have to cut mine shorter, I used all of the adjustment and I am still about 3/4 of a turn from being where the wheel should be.
    BlazerBoy
    <a target="_blank" href=http://www.geocities.com/generalblueballs/>http://www.geocities.com/generalblueballs/</a>
  12. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Hey Wes,
    I believe that the First Gen. K5's are the only trucks that can run the straight drag links with no crossmember mods. That is unless the truck is just a black top beauty that hits a few mud puddles after it rains and never flexes. [​IMG]
    It would be pretty easy to build a nice angle shim that sits between the frame and the steering box to correct for the last little adjustment with the bent drag link. It would not take much since you know it would be less than one full thread on the drag link end. Just a thought.
    See Ya,
    Keith
    Oh yea, one more thing. Stephen at <a target="_blank" href=http://www.offroaddesign.com/>ORD</a> is custom making his bent drag link to your truck specs when you order it so it would probably be perfect from the get go. You might want to talk to him since he has put alot of research into his kit.
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
