Anybody shim their front D60?
Discussion in 'The Garage' started by Desert Rat, Jun 18, 2005.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Where did you get your shims and they are a 3 piece set as I understand it right?
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i shimmed mine, just slapped a hunk of steel on the bandsaw and cut it at about 7*.
    i never counter shimmed the bolt heads and havent had problems yet.... 2 or 3 trips
  3. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Anybody else? Looking to do just a 2 degree shim. Where to buy?
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Try here. He has 3,5,7,10 degree shims listed, but should be able to make you some 2 degree shims. He is also a member of ck5
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    3 piece set?
  6. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Yep, 3 piece. PM'ed you.
  7. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    sorry, not to hijack the thread, just didnt want to start another shim thread.
    how do you figure out what shim you need? or should say the easiest way?
    i have 10" Superlift springs, move my shackle mount back like in the Tech Section, and added a set of DIY 6" shackles.
    my pinion is approx parallel with the ground with my Dana44, so when i swap in my Dana 60 im assuming thats not going to change and i would still need to correct that, right?
