Anybody towing with a newer 1/2 ton
Discussion in 'Tow & Trailer' started by wayne, Dec 28, 2003.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just looking to see if anybody is towing a K5 with a 88 or newer 1500 series truck, preferably a 4x4 extended cab short bed with a small block. We are going to be hunting a tow rig soon and I prefer to get a 3/4 or 1 ton but looking for some feedback on how the 1/2 tons do with over 7000 pounds behind them. Keep in mind we will be towing up and down mountains to get to our wheeling spots.
  2. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Well, I have been towing mine around on a towbar behind my wifes 2001 Ram 1500. Its 4x4 with a 318 and an auto, shortbed quadcab. It pulls it along very well, with no problems at all. Mind you, there arent any mountains I have to contend with yet, and Im not sure Id want to without some sort of brake setup on the K5 to help out. (but thats another post hehe) I have been thinking about a trailer, either a lowboy flatdeck ball hitch type, or a recent find a 18' fifth wheel highboy. Im still thinking, but they are both equipped with two electric braked axles ... have yet to find out if Id come in under my weight for the tow rig/ trailer combo. My K5 weighs in at 5500 lbs with no top or doors.
    Later
    Mike [image]http://coloradok5.com/photos/showphoto.php?photo=9325&size=big&password=&sort=1&thecat=500[/image]
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Therobzilla tows his gen 1 with a 1/2 ton 2wd extended cab shortbed dodge. It won't set any speed records but you can park it and drive past a gas station when you aren't towing. I tried to use my dad's chevy Z71 (1/2 ton extended cab short bed) it didn't like it, I didn't like it, my dad didn't like it, but it worked.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    IMHO, do not get a 1/2 ton for towing that kind of load. The 3/4 is a much better choice for towing that weight. I've towed with everything. 1/2ton - 1ton. The 1/2 ton is just not suited suspension/drivetrain/brakes for 7000lbs even though the manufacturer may say so.
    My .02,
    John
  5. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    My Dodge 1500 is equiped with Air Bag rear suspension helpers, and Rancho RSX shocks. Along with the fact that I use a weight distribution hitch with the trailer and have electric brake on both axles of the trailer.
    I also have a K&N air filter and a Throttle body space and run a heavy duty trans cooler. I don't drive like a physco and or set any speed records. I also have an old Alaskan slide in camper in the back of the Dodge. It's works as long as you keep your patience and stay aware of what you are doing.
    I would not do this if I had a better tow rig. Still looking and just can't afford one yet.
    Rob
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Towed my old blazer 1000 miles with about 8,000 lbs combined trailer weight. Did it with my dad's 2001 ext cab short bed 5.3 chevy 2wd. Pulled it amazingly well and at 65 mph on the flats. bogged down on hills, but what do you expect. I was very impressed with that truck for pulling as a 1/2 ton!
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I towed a Bonneville on my trailer from East Coast to West Coast using a 98 Ram 1500 360 with towing/cooling package. I also used it towing my buggy around for a while. Not exactly fun or fast but it did the job just fine.
    But I was worried about the transmission, and I can't stand not being able to hold speed on a grade. I now drive a 2500HD Duramax/Allison so that should say the rest...
  8. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    You can pull about 9k with the newer 5.3's, as long as it has 4.10's.
  9. mountainibis
    mountainibis Registered Member
    Jan 29, 2003
    75
    Morrisville, NC
    I've got a 99 Siverado, regular cab, long bed, 4.8, 5 speed, and 4.10s. I have a K&N FIPK and dual exhaust.
    I've towed a couple of heavy loads. I towed a '69 Bronco from NW NC to Charleston, SC. The Bronco was on a U-Haul car hauler. It did alright on the flats, but it bogged down bad on any bit of a hill. I also pulled a Ford 9n tractor up a road that had a 9% grade for about four or five miles. And, I've also pulled a trailer loaded with Christmas trees (heavier than you might think - over 5000lb.).
    IMHO, don't even look at a 1/2 ton. Yeah, it gets the job done, and does fine in flat areas, but I had it in 3rd gear, standing on the skinny pedal, and running high rpms to get that tractor up the hill.
    FWIW,
    Jim
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Are you sure the 1500 trucks are rated that high?? A 2500HD with the 6.0L and 4.10's is only rated up to 10,000 lbs. for a trailer so I can't imagine an 1/2 ton with the 5.3 being rated at 9,000................
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you have one use it, but if you're hunting to buy, go for a 3/4 ton or a 1ton, you will not regret it.
    /forums/images/graemlins/thumb.gif
  12. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    My buddy pulled my 69 Furd F250 for me about a year and half ago. We flat towed it about 20 miles over some slight hills and a lot of curvy road. His truck is a 99 regular cab, short box Z71 with a 5.3L. He's got some metric 33's on stock tires. It struggled a little on the hills, but it did a good job, especially considering my Furd tipped the scales at just over 3 tons!
    Kris
