anybody use a 99 or newer rear axle???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Feb 17, 2002.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    just wondering how much work wouold be involved to mod a 99 with rear disc to fit an 89.
    Also i have heard you should look for a van axle cause it is wider
    my rear must have a bad bearing somewhere cause it is starting to groan when slowing into a curve, and every thing else back there has been replaced
    any ideas???
    thanks
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    anybody have an idea if it wilol work????
    what's in it now?
  3. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Not to sound like a smart-ass.. but anything can work if you have mean's.. ie: welder, cutting wheel etc to do some fabrications and modifications..
    I don't see why it wouldn't work though..
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    I don't know of any reason of why it would be any more work than using an '88-98 truck rear end. either one needs the perches and mounts moved. The only exception is that you would have to change the brake proportioning, which might be as easy a getting the prop valve from the donor truck.
    <font color=green>Top signs you don't have a real 4x4:
    4) Twin Traction Beam
    3) Made by D.C.
    2) 5 lug nuts
    1) Unibody</font color=green>
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Get out the measuring tape before you buy. Check the width of the axle, from flange to flange. The later trucks use wheels with a different offset, so the axles may be a tad wider to make everything fit properly.
  6. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    yeah, i knew i could MAKE it fit, i have a mig, torch, and assorted grinders, but was hoping to find someone that has done it, and could tell me some details.
    will my rims fit
    do i have to move the perches and shock mounts
    are they wide enough so dont have to have the wheel spacers etc
    thanks
    chris
    what's in it now?
